Does the 3.4 require pcm tuning after ........
Old Mar 27, 2006 | 10:41 AM
DB75's Avatar
I installed pacesetter headers, flowmaster catback, k&n cai, asp underdrive pulleys, and 180 t-stat last week on my '95 3.4. I got rid of the a.i.r. equipment since the headers had no provisions for it. The car seems to fall on its face down low and doesn't pull up top until 3,000 rpms or so. There is a service engine light that goes on and off and it seems like the car is starving for fuel. Are these bolt-ons too much for the stock injectors and is there anybody that can tune the 3.4?
Old Mar 27, 2006 | 01:16 PM
MarcR94v6's Avatar
Re: Does the 3.4 require pcm tuning after ........
only one. http://www.fastchip.com/
I have the same bolt ons as you (except 160* stat and pulleys) and I get pretty good low end response. My car doesn't have A.I.R though, maybe there's a diff. between 94 and 95??? My fuel is richer than it should be, so I should get a 180*, so I'm not sure why yours would be starving for fuel, it should be getting slightly more, but still it sounds like your 3.4 isn't performing as well as it should.....but we're talking 3.4 capabilities here.
Did you swap the alternator pulley with an underdrive in your UD pulley kit? I did that once and it killed my performance because of the lower voltage.
Old Mar 27, 2006 | 02:36 PM
DB75's Avatar
I spoke with someone from fastchip and he said that he was able to tune the pcm for stock injectors; nothing bigger and/ or aftermarket. What size are they 16, 17 lbs.? You're right maybe I'm getting too much fuel plus the car does smell rich. How much horse do you think the stock injectors can handle? I didn't think I'd have any problems with a few bolt-ons. I'm sending the pcm out tomorrow and should have it back by next week. Until then I'll just keep my fingers crossed and hope this solves the problem. By the way I have the alt/ ud pulley kit from asp with no charging problems so far. Later.
Old Mar 27, 2006 | 03:32 PM
MarcR94v6's Avatar
Could have just been me/old alt on my car. Just keep an eye on it once and a while.
Old Mar 28, 2006 | 12:09 AM
MarcR94v6's Avatar
i wouldn't say you're getting too much, maybe just a little more. I am more than likely getting too much. Tomorrow, probably, I'm swapping in a 180*.
Old Mar 28, 2006 | 05:47 AM
2000GTP's Avatar
With those mods., tuning is not required but it may help extract a couple more ponies and improve drivability. However, it sounds like you have another problem going on there and a PCM tune will not help that.
Old Mar 31, 2006 | 06:15 AM
DB75's Avatar
I started wrench'n on the car again yesterday. Come to find out there was a loose connector underneath the coil packs. I also pulled the upper intake to find that the gasket was dryrotted. I've decided to replace all the gaskets and should be receiving my pcm back any day now. Somebody from Fastchip called me yesterday and said that he couldn't delete the egr codes from the pcm. I'm not sure why but it doesn't really matter at this point. Hopefully I'll have everything back together over the weekend. Thanks to everyone who responded.
Old Mar 31, 2006 | 01:59 PM
jonathan_abilene's Avatar
its illegal to mess with emissions; dont know how illegal
Old Mar 31, 2006 | 04:54 PM
2000GTP's Avatar
Then there are alot of people on this board breaking the law.
Old Apr 1, 2006 | 04:21 AM
i never said that I am a law abbiding citizen; i try to be
i dont even know how illegal changing your emissions is
Old Apr 1, 2006 | 05:56 AM
2000GTP's Avatar
I'm not positive on the full extent of the laws... I don't think they will slap the cuffs on ya, but I do know you can get a hefty fine. Here in IL, there was a guy who put on headers and removed his cats. The emissions center found out and he got fined 10 grand!
DSMKilla
May 26, 2015 10:10 PM
thenewkid
Apr 12, 2015 07:42 PM
chuyz28
Apr 9, 2015 09:36 PM
nikolt1
Feb 27, 2015 09:10 PM
Killer94z
Jan 13, 2015 12:06 PM
