What would happen if I removed my Cat when installing my flowmaster CAT back?
Old Dec 20, 2005 | 09:37 PM
34v6needhelp's Avatar
Well I am going for the lowest rumble I can get from my 3.4 95...will removing the CAT and just going from my "Y" pipe to the CAT back help with the RASP?
I am thinking of going with the Flowmaster American Thunder Exhaust System - Dual Rear Exit http://www.autoanything.com/products...3&v_id=1986793
Any advise?
Old Dec 20, 2005 | 09:57 PM
MyShibbyZ28's Avatar
Re: What would happen if I removed my Cat when installing my flowmaster CAT back?
You don't need to get rid of the cat for a deeper/louder sound. I have a flowmaster 40 series on my LT1. Yeah it is a bigger engine, but at idle it is deep, and under a hard flooring, it roars. It definitely is not quiet. Good tone, good roar when you floor it, and not too loud inside the car either.
Check out the different sounds
http://www.flowmastermufflers.com/sound.html
Old Dec 21, 2005 | 12:36 AM
thanks for that link...but all thoes sound like they are V8's...won't they sound alot different on my V6?...I liked the 40 Series Delta Flow sound the most...will that still be a lower tone on my V6?...I can't find any cat backs with that muffler on it...
Old Dec 21, 2005 | 05:06 AM
MarcR94v6's Avatar
Listen to the 40 series on my 3.4
http://videos.camaroz28.com/Player.a...7FFCD5ADB4&p=0
I couldn't get a dual catback to work with it, but you probably can do a custom job wth duals. Any catback will fit, just replace the 40 with whatever the catback calls for, only iit may not end up being a dual exit.
Old Dec 21, 2005 | 11:20 AM
Is that about as low of a tone we can expect out of our V6's?
Old Dec 21, 2005 | 12:26 PM
Pretty much.
Old Dec 21, 2005 | 01:10 PM
Tru2Chevy's Avatar
Well, since you have a v6, you will always have some rasp. A cat will help quiet that rasp, however a bullet muffler will also help, and you can drop a bullet muffler in place of the cat for better flow.
- Justin
Old Dec 21, 2005 | 04:28 PM
- Justin
Cool, what if I leave the stock CAT and put a bullet muffler in the "I"pipe?
Old Dec 22, 2005 | 11:32 AM
Tru2Chevy's Avatar
That will tone down the rasp even more....but the cat will cost you more power then the bullet muffler.
Not sure how inspection works down your way, but up here in Jersey we don't have emmissions testing for 96+ OBDII cars, they just scan the computer for codes. What a lot of guys do is remove the cat, take off the two heat shields that are on it and weld them around the bullet muffler, then install the bullet muffler where the cat was. This allows them to retain the appearance of a cat (so they can pass the visual inspection) and have better performance.
- Justin
Old Dec 22, 2005 | 01:05 PM
Black94Camaro's Avatar
No inspection here either. I just took it to a local muffler shop and they gutted that baby right out.
Old Dec 23, 2005 | 12:42 PM
So best would be high flow cat, and bullet muffler in 'I" pipe...right?
So for now flowmaster cat back...
Next month (after Christmas debts are paid) order and install a 2.5in bullet muffler (I went with the bolt on 2.5 flowmaster CAT back system)
And next add a high flow cat.
Each the bullet muffler will make the tone lower, and the high flow CAT will make the tone lower...is this correct?
So I should have a good sounding CAT back setup when done...right?
Old Dec 23, 2005 | 06:04 PM
PaganEgyptian's Avatar
I just used a Summit 3" Glasspack on mine, and didnt even bother with a muffler. I have a 3.8L -Tim
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
94B&RZ-28
Dec 22, 2008 10:00 AM
Jul 4, 2005 05:00 PM
tubby
Oct 13, 2003 09:16 AM
