P1406 DTC code question
Old Dec 7, 2005 | 11:51 AM
smithtim's Avatar
HI, I had a SES light come on a few weeks back and it read P0441 & P1406 on a 97 V6 firebird.. I started with the P0441 and guessed that it was the purge valve or switch so I replaced both for and then cleared the code.. so all is fixed ... yeah right the good news is the P0441 went away permantley but only the P1406 (EGR pintle) came back on for about a day and then went back of on it's own.. is it possible that these codes are related and if I don't replace the $200 EGR valve that most likely in a few weeks of driving I will again be having problems?? or is it more likely that they were completely different things??? ... I have heard the P1406 is not really a problem with the EGR but that the computer is not just reading it perfectly so throws the code..
any help would be greatly appreciated for a newbee here..
Tim Smith
Daytona Beach, FL
-- driving to work every day in a 97 V6 ... but the XM 46 has me dreaming about going back 30 years to 67 Y camero
Old Dec 8, 2005 | 04:27 PM
PaganEgyptian's Avatar
Re: P1406 DTC code question
I have been told by many mechanics that our EGR system has test codes programmed into it. That if strange codes pop up, its probably just the test codes not working right. You can delete the codes with a PCM tune and shut it off completely so you wont have to worry about EGR again. Besides, EGR only operates at or around 40mph. something a sniffer wont detect. -Tim
Old Dec 9, 2005 | 11:43 AM
smithtim's Avatar
thanks for the info... if the EGR only works at 40mph I sould be fine as 90% of my driving is open interstate..
again I apprecahite the info
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
David Dorris
Jan 17, 2015 08:10 PM
cmdeshon
Dec 27, 2014 10:06 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
