Underdrive pulley...
Old Feb 22, 2006 | 03:26 PM
zkmfdmz's Avatar
ok...so i found it bought it and i have it, im reading these instructions and it doesnt look too hard, anyone here installed one before got some tips for me?
Old Feb 22, 2006 | 07:18 PM
Gr95camaro
Guest
Posts: n/a
Re: Underdrive pulley...
Originally Posted by Fastest Green 3.4
sorry i never did it before.........i dont even know what an underdrive pulley does
LOL
Old Feb 22, 2006 | 07:20 PM
zkmfdmz's Avatar
its a 1/3 size of the original crank pulley which SHOULD save some power
but i was wondering since it spins more it might wear out quicker?
Old Feb 22, 2006 | 08:40 PM
MarcR94v6's Avatar
is it the crank and alternator pulleys or just the crank underdrive pulley?
Old Feb 24, 2006 | 10:18 PM
zkmfdmz's Avatar
just the crank
i kinda need my alternator to charge lol
i got a system
Old Feb 25, 2006 | 01:33 AM
Camabird's Avatar
They prolly have a water pump pulley available as well.
Old Feb 25, 2006 | 03:04 PM
MarcR94v6's Avatar
The crank was difficult to me, because I couldn't fit a impact wrench in there, so what I did was I got a big "cheater bar" borrowed from my hydraulic jack that fit over my socket. That didn't work either, because it would just turn the crank, and not break the bolt loose, I couldn't turn it fast enough, so what I did, is I figured which way the crank turns when you start the car, and I placed the bar towards the ground over the socket while attached to the bolt, cranked the engine, and the force of the crank roating and pushing the bar on the ground broke the bolt loose.
The crank/alt set killed my alternator. So it is good that you got just the crank. I may be getting that someday as well, even if it is only 3HP or so.
Old Feb 26, 2006 | 02:04 PM
GALIATHON's Avatar
so marc your saying that the whole set will kill my alt.. becaused i just orderd the whole set..
Old Feb 26, 2006 | 02:51 PM
MarcR94v6's Avatar
Not necessarily.....I am thinking that my alternator was already going out and the lower voltage caused by the pulley did it in, really. It was the car's original alternator too. So no, I have no proof that it will kill your alternator, but I will tell you to be careful and watch your voltage, don't go on any long trips until you're sure that your voltage is good. I told the story of how they killed my alternator, and everyone that had them (about 3 or 4 people) said they had no similar problems, but some did suspect it.
Here's the thread on it:
http://64.65.63.61/forums/showthread.php?t=387515
Slayer
Aug 17, 2015 03:55 PM
Rde Bandit
Mar 21, 2015 10:17 PM
BadAndy743
Sep 16, 2002 06:11 AM
GoFast908Z
Sep 14, 2002 09:52 PM
Z28BillM
3rd Gen / L98 Engine Tech
Jul 29, 2002 10:17 PM
