plugs and wires?
Old Dec 14, 2005 | 02:00 AM
Mrcoffey's Avatar
plugs and wires?
My spark plugs are do for replacing, and I think i'll replace the wires too while I'm at it. What are some decent brands for plugs and wires, and what gap do most of you guys use on the plugs?
Old Dec 14, 2005 | 03:38 AM
2000GTP's Avatar
Re: plugs and wires?
The stock Delco plugs/wires are still a good replacement. Otherwise, MSD wires are another popular alternative. The recommended spark plug gap should be printed on one of the stickers in your engine compartment.
Old Dec 14, 2005 | 07:29 PM
crasher88's Avatar
yeah just stick with acdelco rapid fire platinums(sp?) for the plugs. And as for wire you can go with either a/c delco or some really thick msd wires your call its your money.
Old Dec 15, 2005 | 03:24 AM
Mrcoffey's Avatar
thanks for the input guys : )
Old Dec 15, 2005 | 11:39 AM
ImportKILLER's Avatar
I'm running Delco Iridiums, but I had no problems with the Rapidfires in the past. They are a fine plug.
As for wires, I believe that protecting your wires is more important than the brand of the wire. I had my OEM wires replaced with another pair of OEM wires that only lasted 20k and replaced them with Taylor wires. However, with the Taylor wires, I installed boot protectors and some insulation on certain spots.
I'm still running the same wires 40k miles later, though I should replace them before they fail.
Old Dec 15, 2005 | 11:45 AM
valter's Avatar
NGK TR55IX + some taylor/msd wires
Old Dec 17, 2005 | 05:14 PM
GALIATHON's Avatar
I use NGKTR55 AND TAYLOR WIRES 8MM NO PROBLEMS
Old Dec 23, 2005 | 06:47 PM
PaganEgyptian's Avatar
Post Re: plugs and wires?
With a PCM Tune and Ported Throttle Body on my 99 Firebird, Run 9mm Ford Racing(Taylor) Wires and NGK TR-6 plugs. -Tim
PCLZ28
Dec 24, 2015 05:19 PM
charchri4
Apr 14, 2015 06:40 PM
eanhl2004
Apr 4, 2015 12:01 PM
IRABuss
Sep 7, 2011 09:08 PM
gh0st
Sep 1, 2002 10:24 AM
