View Poll Results: Rate my car in percent complete: (see below for completed upgrades!)
0% - 9%
68.75%
10% - 19%
12.50%
20% - 29%
6.25%
30% - 39%
6.25%
40% - 49%
0%
50% - 59%
0%
60% - 69%
0%
70% - 79%
0%
80% - 89%
0%
90% - 100%
6.25%
Voters: 16. You may not vote on this poll
V6 Driveshaft busted...again(?)
Old Apr 9, 2006 | 01:51 PM
450HP_V6's Avatar
Question V6 Driveshaft busted...again(?)
Okay guys, this is a brain stumper...
I have a '98 3.8L V6 automatic, and with my thousands of dollar of upgrades, I've estimated a rough 275 RWHP (I'm probably blowing my own horn here). Anyways, meraculously I've managed to bust two (2!) driveshafts, both at the center link bearing, and an additional blown head gasket.
My question is:
WTF IS GOING ON HERE?
The first question I usually get is "how often do you peel out?" The anwser is: probably once or twice a month, and ususally while its raining. I've had half a dozen mechanics look at my car, and they all say that it's probably because I drive the car too rough (which I thought was BS because how can a V6 do this much damage(?)). Whats going on guys? I honestly baby this car better than i do my wife!
P.S. look at my upgrades and tell me what I'm missing. I'm lacking power, and i still dont know where.
UPGRADES:
Magnaflow Catback exhaust
Magnaflow offroad catalitic converter
Custom ram air grill Intake (mostly K&N)
2 electric superchargers
Bosh +4 plugs
MSD 9 mm super conductor plug wires
COMP Cams hydraulic roller camshaft
Throttle body bypass
SLP 180 thermostat
PCM computer programming and diagnostics
Bear GT+ F&R braking package
MSD BoostTiming Master
Holley In-tank fuel pump
Aeromotive adjustable fuel regualtor
many new tubes, plugs, sleeves, and adapters
RedTop coiled battery
BMR lowering spring kit
BMR control arms
BMR strut tower braces
ASP underdrive pulley system
PCV valve
Aeromotive Pro series fuel filter
EVERY premium fluid/lube/additive you can imagine
new drive belts
RKSports ground CA-300 effects
RKSports Super Wing
All Xenon lighting
C5 18'/8.5' F, & 19/10 R crome Corvette rims
Many Interior upgrades
Complete sony X-Plod sound system (including 4-12' subs w/6000watts)
and various decals
Old Apr 9, 2006 | 03:28 PM
GRNcamaro's Avatar
Re: V6 Driveshaft busted...again(?)
i hate to burst your bubble but all your mods are like appearance and sound? new drive belt and PVC those are mods? electric super chargers hey what did you mom say about stealing her blow driers? lol j/k
if your snapping v6 drive shafts at the center which i find really odd why not just throw in a v8 drive shaft?
and your poll makes just about as much sense as your mod list does?
by the way welcome to the site
Old Apr 9, 2006 | 03:51 PM
2000GTP's Avatar
You could pick up a steel LT1 driveshaft used off one of the board members for around 15 bucks. That would be a quick upgrade. Yeah, I also hate to burst your bubble, but I'm really skeptical about you making 275 horse at the wheels with your mods.
Old Apr 9, 2006 | 04:56 PM
MustangEater82's Avatar
Get a lt1 drivehshaft locally... $15-25 if you want an upgrade an aluminum 1 piece one from a ls1 goes for about $75-150ish...
Any times or dyno runs?
Old Apr 10, 2006 | 02:12 AM
jonathan_abilene's Avatar
they must've been bad driveshafts, were they balanced and everything?
Old Apr 10, 2006 | 05:45 AM
GRNcamaro's Avatar
i would honestly say if your buring up drive shafts at that point i would check then for bearing failer cuase i dont thing your puting out that much by and if you were still i would be more incline to think something is out of wake cuasing bearing failer and cuaseing it to break the drive shaft
Old Apr 10, 2006 | 08:39 AM
MyShibbyZ28's Avatar
Just like others have said, get a one piece driveshaft from a v8 car.
Old Apr 11, 2006 | 06:50 PM
450HP_V6's Avatar
Hey, thanks guys.
I guess you're right. but can you really get a driveshaft for only 15 bucks???
GM sells them for $550!!! I thought it was wierd, but i know you can pick one up from the local junkyard for about $25. (which is what i did once). But a V* driveshaft cam fit into a V6, huh? hmmm I'll check it out. Thanks again.
Old Apr 12, 2006 | 07:08 AM
Shirl's Avatar
You can get an aluminum one piece driveshaft from gmperformance parts for about $270 or so... Looks like your car would be running low 14's or so with the cam so it seems odd that the ds would be breaking but you should get a one piece and try that.
Old Apr 12, 2006 | 07:41 AM
Originally Posted by 450HP_V6
Hey, thanks guys.
yep direct bolt in...
Old Apr 14, 2006 | 12:38 AM
LTR450HQ.com's Avatar
Get an ls1 driveshaft off of a camaro ss/ws6/firehawk/z28/formula/ta
So do those electric blowers actually do anything? lol
Old Apr 14, 2006 | 05:23 PM
93redBirdMan's Avatar
first off, you DO NOT have anywhere close to 275rwhp. Secondly, 2 electric superchargers?? HAHAHAHAHAHAHAHAHAHAHAHA!!!!!
Old Apr 15, 2006 | 11:20 AM
johnny3986's Avatar
Guys, c'mon...leave him alone on those electric superchargers...he was just trying to help pay the bills of whoever he bought those off of on eBay...
Just flat leave him alone on the superchargers.
The
and various decals
were what put him at 275 driveshaft-snapping-horsepower...
Old Apr 15, 2006 | 12:17 PM
HM, im gonna hook up my blow drier...
Old Apr 15, 2006 | 02:07 PM
PaganEgyptian's Avatar
Post Re: V6 Driveshaft busted...again(?)
Thats Odd, Unless the driveshafts are different on non-Y87 cars. Mine came stock with a LS1 Driveshaft. you must have had bad carrier bearings. Because our D.S. are stable to over 500hp if in good condition, the rear end is a whole different story. -Tim
