maybe a dumb question
Old Dec 30, 2002 | 09:05 PM
Timberwolf's Avatar
Why did GM change the firing order for the LS1? Is there any advantage to this order, beside the more balanced back and forth L,R,L,R... instead of L,R,R,L,R,L,L,R ??
Old Dec 30, 2002 | 09:13 PM
PhantomTA's Avatar
Moderator
isnt it the same the pro stock guys run?
Old Dec 30, 2002 | 09:15 PM
Timberwolf's Avatar
dave, yep...just wondering why
Old Dec 30, 2002 | 09:19 PM
96SFLZ's Avatar
Besides a smoother idle?
Probably not but maybe.
Old Dec 30, 2002 | 09:25 PM
96SFLZ's Avatar
Not to me, my '02 idles a lot smoother than my LT1 did.
Old Dec 30, 2002 | 09:38 PM
Timberwolf's Avatar
Would the alternating bank firing system help reduce the need for a crossover pipe on a true dual system since the exhaust pulses would be evenly spaced instead of doubled up every other time?
Old Dec 30, 2002 | 10:02 PM
Timberwolf's Avatar
ok, how about these ideas:
Firing order as it was, had 5 firing right before 7 (adjacent cylinders). Seems like this could
A) Create excessive heat between the cylinders. Anyone know where the most common block and/or head crack area is?
B) Create fuel/air delivery problems? With those two firing right together, can the intake accurately deliver the SAME amount of fuel and air to each cylinder, or will the first cylinder rob a little of what should go to the second? And would this second problem be solved by direct port fuel injection?
ModdedNerd
Dec 25, 2014 05:51 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
donot_4get
Sep 14, 2002 08:03 AM
