Finally found out 99 ls1 injectors will work on 3.8 need help on fuel pressure
I recently received a picture of a 26lb 99 ls1 injectors and it looks the same where the connector is so im pretty sure it will work, im just confused because the ls1 sprays 60 psi fuel pressure and my v6 is only 50 psi, how would i compensate for this so i could properly run the ls1 injector? I will be getting my pcm programmed and using a walbro in tanks pump but how wil i get it to spray at the right fuel pressure on my 96 3.8 thanks for any help
Gtpguy
Jan 26, 2015 04:50 PM
Jul 4, 2005 05:00 PM
