Bad Code
Old Dec 30, 2002 | 10:40 PM
willy's Avatar
Bad Code
Had Auto Zone scan car today, it came up with PO440. Any help with what that is would be great.
Old Dec 31, 2002 | 06:47 AM
PhantomTA's Avatar
Moderator
Evaporative Emission (EVAP) System
Old Dec 31, 2002 | 09:43 AM
willy's Avatar
What is that and what do I need to do to fix it?
Old Dec 31, 2002 | 10:40 AM
PhantomTA's Avatar
Moderator
Replace the pump maybe?
Old Dec 31, 2002 | 01:05 PM
willy's Avatar
I hate to say it, but I'm still lost.
Old Dec 31, 2002 | 01:32 PM
2001NBMZ28's Avatar
Found this on the web from a guy with an account with Alldata:
"The EVAP large leak test is based on applying vacuum to the EVAP system and monitoring the rate of vacuum decay. The PCM uses the input from the FTP sensor in order to determine the rate of vacuum decay. At an appropriate time, the PCM turns the EVAP canister purge valve on (open) and the EVAP canister vent valve on (closed). This allows the engine to draw a vacuum on the system. At a calibrated time or vacuum level, the PCM turns the purge valve off (closed), and tests the system vacuum. If the system is unable to achieve the calibrated vacuum level, the PCM will set DTC P0440."
Sounds complicated. I'd try resetting the PCM, if the code returns you may need to take a trip to the dealer. Hope this helps.
Old Dec 31, 2002 | 08:08 PM
ss rally red's Avatar
Most EVAP codes are simple and inexpensive to repair. At my shop in Ga. we do Emission's testing & repair's so we see quite a few EVAP codes. Sometime's it is as simple as a new gas cap, other times it may need a solinoid replaced in the system,GENERALY it is inexpensive to repair. We have Alldata at the shop but without testing individual componets on your car your just guessing.If you get any other info on your problem e-mail me and if I can help you in any way will be glad to.
Old Dec 31, 2002 | 08:37 PM
willy's Avatar
Thanks everyone for the help. I went to the chevy dealer today, they printed me about 20 pages of stuff to read. I have a few things to check and after that I'm lost. I put a new fuel pump in a few weeks ago, they said the hose going to the canister my be lose or not connected. Then theres one by the drivers side valve cover. I changed the pushrods also so I may have left it poorly connected. If thats not it I may have to get up with you SS Rally Red.
Old Jan 1, 2003 | 09:57 AM
PhantomTA's Avatar
Moderator
*****, you have a private message... please read it.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
ad356
Apr 11, 2015 10:30 PM
captcorvette
Mar 7, 2015 12:37 PM
91Bird305
Aug 8, 2002 12:36 AM
91Bird305
Aug 5, 2002 01:39 PM
