digital gauges in gauge pod.......
Old Dec 28, 2002 | 08:07 PM
stik6shift98's Avatar
like air fuel........etc
they have them at summitracing and i was wondering if anyone has them.......???? pics???
how do they hook up???
is there an exhaust temp one?????
thanks
Old Dec 28, 2002 | 10:52 PM
Dark Angel's Avatar
I had a digital Nitrous Pressure gauge I got from www.speedshop.org and loved the look and functionality of it. I was thinking about getting the A/F gauge, but got rid of the nitrous kit. If I put something in there again, I will go digital.
Old Dec 29, 2002 | 01:24 AM
digital is the way to go
Old Dec 29, 2002 | 07:06 AM
Bone Maro's Avatar
I used to have a Cyberdyne digital fuel pressure gauge in my Camaro. It wasn't bad, and looked pretty cool. I paid $90 total for it at Jegs, vice $200 for the Autometer analog one.
But I have an Autometer analog one now because it was free with my supercharger kit and matches my Formula
Old Dec 29, 2002 | 07:14 AM
for 90 bucks did u get sending unit.....or does it not need one
Old Dec 29, 2002 | 08:14 AM
Bone Maro's Avatar
It was a total of $88 or so, but I picked it up since Jegs is about 5min from my house.
It did come with the sending unit, wiring, gauge, and instructions. But, you will need an adapter for a 1/8" NPT(female) fitting to 4AN connection(female).
The schrader valve in your fuel rail is the 4AN connection, but the connection on the sending unit is the 1/8" NPT. Most speed or machine shops can make one for you for about $20 or so.
Basically, you run the fitting from the schrader valve to the sending unit. You plug in the wire-pack plug into the sending unit, and run the wires to the gauge. The total install once you have everything is about an hour.
I've done this several times, so buzz me if you have any questions
Old Dec 29, 2002 | 08:40 AM
sweet.......ya ill prob need help ill keep u in mind
Old Dec 29, 2002 | 10:30 PM
ThirdGenZ28 92's Avatar
Digital Gauges
Its a 3rdgen but notice the one I custom cut into the dash above the cig lighter. They were easy to hook up and look good especially at night...
Old Dec 30, 2002 | 01:10 AM
thats sweet....whered u get yours at thirdgenz
Old Dec 30, 2002 | 08:48 AM
I ordered everything thru Summit and the pod was given to me as a Bday present but I believe that was from Summit as well. The one in the dash I used a 2 inch hole drill and it fit perfectly and it didnt take but a few hours to wire everything up...
Formula Steve
Sep 19, 2023 08:31 AM
drt
Sep 27, 2015 04:39 PM
RX Speed Works
Sep 11, 2015 03:31 PM
jackpawt883
Sep 10, 2015 08:53 PM
themex2002
Sep 2, 2015 03:47 PM
