Air/Fuel ratio tuning..
Old Jan 8, 2003 | 08:28 AM
bbentley40's Avatar
If I take my car to a dyno with wide band sensors do I have to have a MAFT and fuel pressure regulator in order to tune these or is there a way to do it on a stock car? I want to be able to tweak things when I go to get my car dynoed so I just want to know if I need to get this stuff before I take my car.
Thanks all!
Old Jan 8, 2003 | 08:30 AM
PhantomTA's Avatar
Moderator
there really isnt a real fuel pressure regulator for our cars..
you can use a maft.. i ran one for years and i love it..
give me a call @ ramchargers (we make them) 888-293-7267 and ill set ya up
Old Jan 8, 2003 | 08:47 AM
bbentley40's Avatar
Ok.. so I have to have at least a MAFT to actually do tuning on the dyno?
Old Jan 8, 2003 | 10:28 AM
PAGregSS's Avatar
Not if the shop has a shop version of LS1 Edit. They can use that to adjust your air/fuel ratio. May be cheaper than a MAFT.
Old Jan 8, 2003 | 11:25 AM
PhantomTA's Avatar
Moderator
Its not goin to be cheaper than a MAFT.. thats a problem. It was 300+ and then i had to pay for dyno time to get mine done
Old Jan 8, 2003 | 12:04 PM
bbentley40's Avatar
Yeah it would be cheaper for me to just buy a MAFT, most shops I have found that do LS1 editing charge almost what it would cost to just buy a freakin copy. I will probably just get the MAFT and when I get to doing some bigger things I might sell it and my HPP3 to buy my own copy of LS1 Edit.
Phantom, do you guys at ramchargers make your own version of a MAFT or is it the same that can be bought at other sites? About how much would it run? You can PM me with the info if you want.
Thanks!
Old Jan 8, 2003 | 12:50 PM
PhantomTA's Avatar
Moderator
The MAFT is our unit. We actually make it
PMing you right now
Old Jan 8, 2003 | 01:35 PM
bbentley40's Avatar
Phantom,
Does the MAFT work for both the LS1 and LT1 or is it engine specific?
Old Jan 8, 2003 | 02:00 PM
PhantomTA's Avatar
Moderator
MAFT works on both cars
The MAFT+ is LT1 only
Old Jan 8, 2003 | 02:09 PM
bbentley40's Avatar
Oh, ok.. that is what had me confused then the MAFT+.
One last question and I will try to leave it alone. What is the deal with the different versions? I have tried to look some stuff up about them and some sites are talking about older and newer versions. What are considered the "newer" versions and what is the difference? (ok maybe that is more than one question )
Old Jan 8, 2003 | 02:12 PM
PhantomTA's Avatar
Moderator
anything 6.0 and up has a pre set calibration for a factory z06 maf. Otherwise it means nothing to you.. even if you buy a SLP or Pace "calibrated" maf it means nothing to you since you dont use the pre set calibration in the MAFT.
Otherwise any other changes only reflect the turbo buicks.
Understand?
Old Jan 8, 2003 | 03:27 PM
bbentley40's Avatar
I think so..
Thanks again.. as usual you have been extremely helpful!
Old Jan 8, 2003 | 07:18 PM
katman's Avatar
Dave,
I've got a set of anodized TR ends coming to go with the light mods in the sig. Am I in a position where MAFT and dyno time is likely to give me any increase worth talking about (10 or more RHP).
Also, so I have to remove the HPP tuning (I believe it's just +2 timing at WOT) to use MAFT?
Thanks for the help.
Old Jan 8, 2003 | 07:58 PM
PhantomTA's Avatar
Moderator
nope you dont have to remove it.. only if you have knock retard after adding fuel and installing the ends
it could be 10hp.. it might be less.. depends on the car
Old Jan 8, 2003 | 11:44 PM
stik6shift98's Avatar
how much is a maft
also someones selling a used maft vesion 4.1
is 115 a good deal...
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
RUENUF
Mar 13, 2016 03:37 PM
Z Power
Sep 19, 2015 11:19 PM
Aug 7, 2015 01:26 PM
