LS1 headlight harness??conversion? help!
Old Jan 8, 2003 | 08:15 PM
ReznorZ28's Avatar
first off I am doing a front end conversion from a LT1 to an LS1 front end...
okay, I just realized that the LS1 headlights use a different socket for the bulbs... at first sight I thought they were identical, but when I tried to connect them I found they werent.
my question is do they run off the same voltage and everything? Is hooking it up as simple as just cutting the old socket off and splicing in the new socket or is there more to it than that? Because I can cut the actual socket off of a LS1 camaro at the junkyard and get em for $20 or so, but if I have to buy the whole harness it is going to cost alot. Let me know, Thanks!
Old Jan 9, 2003 | 02:20 AM
stik6shift98's Avatar
i dunno but heres a ttt
id think u can just cut it and get one from junkyard
HarleyZ28
Oct 5, 2015 06:23 AM
Brake_L8
Jan 20, 2015 09:44 AM
