Grinding in reverse Gear.......
Old Jan 7, 2003 | 01:25 PM
WipeOutXXL's Avatar
I have had my car for 1 year and 3 months now, its a 2000 SS with almost 50k miles on it. I'm still on the factory clutch (Dual Friction is sitting in the garage, waiting......) but I have been having some shifting problems, and no the Camaro isn't my first manual....even though I still had to relearn with the beastly power...but lately when I put it in revese, it popps in there and it stays but as I let go fo the clutch it starts to grind.....but it's in gear.....i then take it out of reverse put it in again and then it works.....I have tried holding it...if I hold it in pretty hard it will stay the first time....I am thinking syncros but I'm not sure...any one else pop up with this problem?....any of you m6 drivers.....
Later,
Chris
Old Jan 7, 2003 | 07:38 PM
SS1LE02's Avatar
Try throwin it in reverse b4 you start the engine, or if the engines running and it grinds when you try and throw it in reverse, go to first for a second, slightly let out clutch and then go for reverse again. Sorry about the runon sentence.
Formula Steve
Sep 19, 2023 08:31 AM
blac94Z
Nov 4, 2015 01:59 PM
Bxlt1
Sep 29, 2015 03:18 PM
4586
Sep 27, 2015 01:55 PM
