Fuel System
Old Feb 25, 2003 | 08:20 AM
BLOWN25TH's Avatar
Fuel System
After deciding to keep my FMU because tuning issues can you guys tell if this fuel system is going work for my application?
I have walbro 340 intank and ATI's inline pump. Will this be sufficient?
Old Feb 25, 2003 | 09:26 AM
94SLUG's Avatar
I would try the 340 alone with no fmu/inline. If you drop pressure with that setup then add the fmu. 340 is good for 500hp.
Old Feb 25, 2003 | 10:35 AM
BLOWN25TH's Avatar
94slug, i need to keep the fmu for drivability reasons. Because my sysytem is speed density. I need to know if i can ditch the inline pump? And only run the walbro 340 intank. But unfortunalty the fmu is staying.
Old Feb 25, 2003 | 12:23 PM
94SLUG's Avatar
oops ya that should be fine 340+FMU, but whats the ratio on the FMU? If i rem you have a 92 not sure how much hp stock lines will hold. I would run the intank and fmu only!
Old Feb 25, 2003 | 01:04 PM
BLOWN25TH's Avatar
I am not familiar with the FMU ratio. The FMU is the is the one that came with the Procharger P1SC.
Old Feb 26, 2003 | 01:38 PM
sleeperz28's Avatar
Stock lines are good to about 700hp. With the power your making the weldbro will be plenty. If your fuel pressure ever starts droping then its time for the ati inline or bigger pump.
Old Feb 26, 2003 | 02:33 PM
ATI426's Avatar
I believe that the ATI units are adjustable. There is a screw that you can screw in all the way or out. If you look on their sight it will show you on their tech help online.
Brad
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95maroboi
Jun 7, 2015 12:18 PM
Jul 4, 2005 05:00 PM
