Nitrous problem. Won't rev over 5100rpm???
Whenever I hit the juice (nitrous works 125 shot), the car will not rev over 5100rpms at all. It does this on any size shot; 50-150. I've changed plugs from ngk to autolite with no help.
Any ideas?
Any ideas?
Will it rev over 5100 without the nitrous? Have you checked the rest of your ignition (opti, wires, connections, etc?). Also, what about bottle pressure? If you don't have enough nitrous going to the solenoids, then your mixture will go dead rich because of all the extra fuel being injected. Just some thoughts...
