Best Cam For My Combo???
I WAS THINKING OF CHANGING THE CAM IN MY CAR.THE PERSONE I BOUGHT IT FROM REPLACED THE ORIGINAL 517 RWHP COMP CAM WITH A MORE EMISSIONS FRIENDLY CAM.WELL I'M NOT LOOKING FOR EMISSIONS QUALITY.I'M LOOKING FOR THE HIGHEST HORSEPOWER CAM I CAN GET AWAY WITH ON LT1 EDIT.HERE'S SOME DETAILS ON THE MOTOR.355 LT1 W/PORTED AND POLISHED HEADS,CALLIES RODS,FORGED CRANK,4 BOLT CAPS,JE 25CC DISHED PISTONS,COMP CAM SPECS?,58 MM ASM T/B,ASM HEADERS W/ Y PIPE,12 PSI VORTECH.
Originally posted by IDOXLR8
I would recommend a Comp Cams 224/236 on a 114lS. Call Combination Motorsports and they should be able to help you out.
I would definetly recommend this cam too.
DO YOU GUYS THINK THE CAM YOU GUYS RECOMMENDED IS BETTER THAN THE ORIGINAL CAM THAT WAS IN THE CAR WHICH MADE THE 517RWHP. CAM SPECS COMP CAM 229/229 112L/S W 460 OR 480 INTAKE (NOT SURE CAM CARD IS A LITTLE BLURRY)480 EX.
I would say so...It looks like the 224/236 is a better blower cam, you have a numberically higher 114 LSA which will not blow your boost out your exhaust. Plus I believe the lift numbers are like 502in/521ex with 1.5 Roller rockers too, that coupled with the added duration and even more exhaust duration makes It a better blower cam IMHO.
I would also recomend this cam as I just installed it on my car. It sounds great and idles fine. If you already havent done it yet, I would recomend getting some double coiled springs for this cam. Not for the lift but the agressive ramp rate of this cam. Like I said before...It sounds awsome !
oldschool
Feb 9, 2016 09:21 PM
