stumbling in the upper r's
Old Mar 27, 2003 | 12:37 AM
t-trimz28's Avatar
i'm getting a pretty strong "stumbling" (almost feels like a miss) around 4700 and up.
I 'm currently running the vortech supplied crane ignition w/boost timing retard and stock coil. the plugs are ngk irridiums (not real sure on the gap though). The blower puts out around 7-7.5#s on the gauge and the lower-end is bone stock.
i don't know if this is knock retard, but i wouldn't think knock retard would stumble. maybe i'm wrong.
anyone have any input?
-chris
Old Mar 27, 2003 | 02:09 PM
TonyJ's Avatar
Could be the opti... you need a sig line to let folks know what you're talking about. LT1? LS1?
Old Mar 27, 2003 | 03:44 PM
SMOKNZ's Avatar
I would try some different plugs first. Maybe some NGK TR6 or Autolite 103's. Maybe the iridium plugs are causing it, and it would be alot cheaper than doing the opti right away. Did you just put the blower on, or is this something that has creeped up on ya.
Old Mar 27, 2003 | 06:03 PM
engineermike's Avatar
I had that problem and installed an MSD 6AL and it cleaned it up.
The problem came back and I took apart the Opti and cleaned the electrodes in the cap. They had a hard build-up that flaked off. After that, the problem went away.
Mike
Old Mar 27, 2003 | 07:42 PM
t-trimz28's Avatar
thanks mike. i've heard the crane is junk. as far as the opti goes, it's a new gm unit, but i guess you can always get a faulty part.
smoknz- the blower has been on for a couple of months now without any issues so it's a recent problem.
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
tommalcolm
Sep 11, 2015 03:39 PM
jackpawt883
Sep 10, 2015 08:53 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
