Procharger crank pulley question
Old Mar 24, 2003 | 06:05 PM
Arctic_White_WS6's Avatar
I have the 8psi P1SC kit for a TransAm. I've noticed that the crank pulley wobbles about 1/16th of an inch side to side at idle. Is this normal?
I made sure there was no raised lettering on the harmonic balancer and wire brushed everthing so it was perfectly clean as per the ATI instructions. Everything is torqued properly. I haven't thrown a belt with it, but I was thinking it can't be all that good for the crank. The harmonic balancer is running perfectly true.
Thanks,
Brent M.
Old Mar 24, 2003 | 10:36 PM
SC97TA's Avatar
When I first put mine (P600B 8#) on it had a off center wobble, pulled it off and put it back on and it was fixed. Seemed kinda hit or miss. But it sounds like yours isn’t sitting flush on the pulley face is it warped?
Kris
HectorM52
Jun 23, 2016 08:42 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
