Maxed Out MAF???
Old Mar 18, 2003 | 08:17 PM
Highlander's Avatar
Maxed Out MAF???
After 5400rpm the AFR will climb no matter what I do... am I maxing my injectors or is it that I after reaching the 471gps?
I augmented fuel pressure from 45-55 and no change was done...
What happens when you max out the MAF?
MY AFR is deadlined at 12.5 and at 5400rpm its climbing around 45º with no ondulation, STRAIGHT...
What is this???
LMK
Old Mar 19, 2003 | 08:58 AM
94 NO TOP Z's Avatar
Need to scan it to find out which one it is. My MAF maxes out about 4800rpm. You have to power enrich the heck out of it past that point it maxes out in your PE table. If your injectors are too small or not enough fuel pressure you could be maxing the injectors out. What's your combination? Cubic inches, boost, inj size?
Old Mar 19, 2003 | 12:02 PM
Highlander's Avatar
pumping 493rwhp
30# svo and a superfueler (with 2 95's and 1 34.8 after throttle body)
55psi fuel pressure with racetronix high volume high pressure pump.
I think I am maxing my injectors. since the superfueler is maxed out and my PE Tables too...
I have a perfect AFR curve till I hit 5600 with my s-trim @9.5-10psi
Old Mar 19, 2003 | 01:15 PM
Hal Fisher's Avatar
Can you get bigger injectors for the superfueler?
Hal
Old Mar 19, 2003 | 03:15 PM
Highlander's Avatar
Well I can change the 34.8 for a 95 or so.... soon... would that supply the enough fuel? that should be more or less what I need...
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
