headers glowing
Old Mar 30, 2003 | 07:46 PM
FLIPPINZ28's Avatar
Unhappy headers glowing
i installed alchol injection on car. running fine then changed supercharger pulley on a paxton to 9lbs of boost raced a grand national last night and pulled over in the middle of race because car was making a nasty sound under the hood opened hood and headers were glowing red all the way to the collectors and people behind said flames shot out the exhaust can someone help me on this now car is running fine but feels slower thanks kenny
Old Mar 30, 2003 | 08:49 PM
SLPSSLS1's Avatar
yea i know exactly whats wrong, You aren't getting enough fuel to your engine, you need a better fuel regulator, I would check with the company who makes your supercharger for one. Also I dont know if you have one, but better exhaust always helps. I would'nt race untill you fix this problem, other wise you will cause your car to lean out and you will blow your pistons.- let me know how you do - mike
Mikael's Avatar
Most people will say that glowing headers is either too rich or valves too tight, but after a WOT run i don't know.
Old Mar 30, 2003 | 08:50 PM
SLPSSLS1's Avatar
also that sound is your pistons detinating, i promise you that
Old Mar 30, 2003 | 09:11 PM
FLIPPINZ28's Avatar
Wink
Thanks for the help. I am going to get a new feul reg and fuel pump I already have the injectors. They are 30lbs injectors. Do you think this will be enough. Or you know the three fuel injectors that sit on the throttle body for the supercharger came with it they are 36lbs couldnt i just change them to like 50lbs injectors and adjust the fmu that came with the supercharger would that work thanks kenny
Old Mar 30, 2003 | 09:23 PM
Mikael's Avatar
Don't start dumping money until you know exactly what's going on. It could be that you're too rich, and excess fuel is going straight into the header then burning there, which is causing the glowing, and could also cause the flames shooting out the back.
Old Mar 30, 2003 | 09:52 PM
FLIPPINZ28's Avatar
Question
well see i have an air fuel meter it is showing it is running lean no where near the green so i guess that means it is running lean. i dont want to spend money unless i have too what could cause it to run rich?thanks kenny
Old Mar 30, 2003 | 11:19 PM
sleeperz28's Avatar
Headers will also glow if you dont have enough timing into the car. On my last turbo car the manifold would glow like you could not believe. One problem was an ignition miss, causing raw fuel to dump into the exhaust(flames). Then after that was fixed still has some glow, added timing and it was gone. Well until the car went under boost
Old Mar 31, 2003 | 12:40 PM
94SLUG's Avatar
I had this problem when the FPR went. I just went back to the stock unit with no probs. What plugs are you using, and what was the nasty sound? Have a FP gauge?
Old Mar 31, 2003 | 09:08 PM
SMOKNZ's Avatar
SleeperZ28,
Brian will be interested in hearing about that glowing issue
BTW his car is running strong. Auto's and turbo's are the way to go, Now i just need an Auto
Bill
Old Apr 2, 2003 | 08:17 PM
SLPSSLS1's Avatar
if your worried about plugs, a colder ranger of plugs would always help, but check with paxton for a fpr, your pistons already sound damaged, cool things down for a bit untill this is fixed, depending on how damaged they are you might need new ones, but hopefully not. Your biggest concern should be keeping the engine as cool as possible. you are definatley running lean, trust me i have been in your postion before, it sucks. I had it happen on my old car. I had a GTP stock 7lbs of boost i put it to 25lbs and the pistons detinated for a month or two then i blew my first and third piston, smashed my plugs, nitrous cought on fire but i turned the tank of so just the lines blew. and some how i managed to get the warenty to cover it. That why i will only supercharge my ss with a intercooled supercharger. The problem is heat, and the amount of space and time it can be taken out of the engine
Old Apr 3, 2003 | 10:40 PM
t-trimz28's Avatar
....pretty sure nitrous won't catch fire
Old Apr 4, 2003 | 08:07 AM
sleeperz28's Avatar
Originally posted by SMOKNZ
SleeperZ28,
Bill
Bill good to hear about Brians car. Im just about done with mine. Cant wait!
colts0455
Jul 28, 2015 11:28 PM
realistyc
Jul 28, 2015 07:32 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
