View Full Version : LS1 Based Engine Tech
- Slave cylinder mod
- Cam Question
- 1998 LS1 Z, weird idle... help
- cam install
- Which Cam to get???
- Head Gasket (part # ?)
- Macdaddy's Z
- Car runs like CRAP, Help please
- Dart Heads????
- intakes and fuel injectors
- differences b/t '00 & '01 ls1s ? EGR? etc...
- questions on an 01 formula
- LSX intake comparison test - which mag?
- ls6 heads
- which pulley to get?
- Race vs. Emissions?
- When to change springs?
- QUICK ?, will it hurt to drive w/ MAF unplugged?
- just got back from autozone...
- Lazy o2 sensors?
- Clicking Sound
- difference between ls1 & ls6 intake manifold
- Losing Power Steering Fluid
- Resleeving ?
- Starting problem with 99 T/A
- What is a tune worth?
- Which one should I buy?
- 99 TB on a 02
- backfire, misfire when wet now always
- How would you spend $700
- HELP! My LS1 won't GO!
- Questions on intake and induction
- LS1 Problems?
- lid or not
- Why am i losing oil?
- how much $ for cam install?
- Some cam feedback please
- Valve sizing
- The new LS7 ...
- Polyurothaine Engine Mounts. Yes or No? Pros & Cons?
- How much xtra HP with 224 cam & 100 shot?
- Car is Too Lean
- Prices on Installation
- 1.8 Rockers for stock LS1
- TSP Rumbler any good?
- what shoul i do?
- I need part number for the ls1 90mm t/b
- Cats = how much HP loss with headers?
- 2.5" or 3" CATS....
- patriot heads
- Yay or Nay
- timing chain
- Tsp 224r
- Quick Question, I Need Help!!!!
- Cold start rattle
- Pacesetter vs. Hooker
- if only..........
- Pics...
- Hesitation
- Tune Up ??
- Just put flows on and gas gauge dropped?
- Do headers really = dyno RWHP ????
- AIR DTC how to stop it from coming on
- No Cats? Just wondering!
- Yahtzee!!!!!!!!!!
- Futral Motorsports does it AGAIN! AWESOME!
- '02 LS1, common CE code?
- LS1 Burning oil???
- Squealing
- Piston Slap while Warming up
- ls2 oil pan
- Slight lope in idle on stock cammed car
- Dyno Tune?
- How tame can I build a mid-11's heads/cam LS1?
- Cat Back Suggestions
- mid-lengths any good??
- ls1 misfire
- What do you think
- Installing/buying a 2 step.
- Trans Am --98
- have you ever...........;)
- Need Advice PLEASE!!
- Stock Intake On 98 SS???
- P/N for 02 LS1 fuel injectors...
- Will Truck Throttle Body Work? Worth It?
- Full Bolton Numbers
- 98 T/A..is it a problem?
- "ASR OFF" light is on
- LS2 Swap
- Serp belt....
- Throttle Body Spacer?
- SES P0442 - 2nd time
- need fuel part #s
- Emergency Please Help Me!!!!!!!!!!!
- I made the Big Change
- HELP!! Header install, mac mids
- Should I be worried?
- Headers not the normal question
- Rear wheel HP rating on 00 SS
- New exhaust...
- ls1 block integrity
- new Firehawk
- What do you think
- how big can and ls1 go?
- accurate o2 sensors???
- Heads and Cam
- What do stock firehawks put down?
- LS1 street cam
- California Smog?
- 98 LS1 swap into 02 car?
- A4 Vs M6
- stock cam.......?.........?
- Are these heads worth swapping
- Loudmouth II + Headers?
- EGR with LS6?
- LS1 to LS7 or LS6?
- Which LS...
- Selling my 93 Z28 and buying a 2000. Have a few questions...
- header install ?
- Off-throttle response
- LS1 valve spring I.D.
- Why are some of the ls1 guys on this thread so spitful
- what the owners manual says
- a4,,m6???
- Aftermarket MAF vs Ported/Descreened Stock
- Is there any difference between 98s & 99s
- Woes about switching to ls1.
- does LS1 have lowend torque
- edelbrock headers
- 95 Z28 needs motor
- street legal cam??
- Need opinions/help w/what type of headers will work best.
- LS1 vs LT1
- Beginner Performance Mods
- Engine work for dummies
- What gives??
- Service Engine Light after spark plug change
- Buying LS1 Engine w/ 6-speed this summer
- Poly motor mounts
- Selecting heads and cam
- Borla off road y-pipe
- How much Torque
- Can LS1 guys help w/ecu info on 8100 BB
- engine oil
- QTP Header ?
- Quick question on '02 header install
- LS1/6 manifold question
- advantage of AFR 205s over Dart 205s?
- Help
- building ls1 for high rpm
- induction options?
- What are these headers?
- Oil pan Gasket
- mustang dyno seems low!!!
- computer questions
- the right cam
- Ses Light
- Electrical Problems? LS1 1999 Camaro
- mti R1 cam
- header install w/ Y pipe??
- Differences between
- Anything to look for in LS1 car?
- exhaust problems
- whats better Ls1 or lt4?
- Shop Quote: Plugs and Wires
- Valve train work
- Will lt1 body kit fit Ls1 fbody
- v6 to v8 swap, opinions plz
- Wanting to replace cats.
- Fipk, K&n, Slp, ??
- ls6 heads?
- How good is a 98 Z28 (LS1) with 122k miles?
- O2 problems with headers
- SLP Y-pipe question
- how to pass smog..?!?!??!
- Pics of LS1 crank pulley
- bigger, better MAF, Throttle body for LS1?
- 471 cubic inch ls2
- shudder after quick restart...
- Painted Throttle body
- Best chip for my 98 z28
- Help
- FAST 90/90....what are they doing about the 75mm maf?
- Evolution of the LS1 Camaro.
- need help
- What to do next?
- Which one????
- TB question!!
- which setup would u consider
- cam
- LS1 block clearancing?
- Sensor on air baffle - how to remove?
- SLP airlid problem
- Check Engine/Service Engine - MAF error
- LS1 headers, primary length
- Best mods for a 2000 SS Camaro
- 2002 ls1 question
- Coated stainless LT headers?
- What mods are best for the LS1
- Edelbrock intakes for LS1
- Silly question
- BOLTON+CAM guys...w/stock heads...post your MPH/dyno
- Help On Wiring a Predator Diablo Programmer
- Speedometer, Tac, Odometer, and radio stopped working
- need new injector clip/plugin/harness...can I use an lt1 part?
- Dyno test for Christmas!
- It's all here...
- First Tuneup for Z28's LS1
- 383sb Questions...
- Spark Plugs
- V6 to LS1
- couple questions
- 98 LS1 lifespan?
- RPM at Idle??
- Question about the 99-02 Camaro engines
- Question about some 6 speed cars
- New dream is it to much? LS7
- looking at a 2000 z28 m6, what if any problems should I look for before purchase?
- Power Programmer?
- LS1 WS6 Ram air exhaust on my 2000 Z28
- Blown LS1
- change valve springs??
- Exhaust
- Idler pulley
- High RPM Miss...Suggestions...
- LS1 vs. LS2; which has more potential?
- Question about true dual install
- MAF Ends??
- help! cam&head????smoke from exhaust!?!
- Headers
- newER car question?
- How will I like this Exhaust Setup????
- LS1 throttle body help
- TR Cheater-Cam, Stock Heads and LT headers
- Bolt ons where to start
- adjustable fuel pressure regulator
- 98-99 00-02 power difference?
- whats it take to get to 450hp
- Split Fire Plugs
- ls1 spec
- Horsepower
- True Dual setup
- LS1 boring question
- Boring questions....
- 02 Z28 Backfireing!
- Quick Question
- Has any one seen the LS7 yet.
- new here
- Does this sound right? (Voltage Issue)
- what does it take to get 650hp?
