RPM at Idle??
Old Jan 1, 2006 | 09:32 PM
deleonm's Avatar
RPM at Idle??
I have a stock (i hope it is) 98 Z28. When the car idles down from ignition. I am running around 900 RPMs. Is this right, or is my idle to high???
Old Jan 1, 2006 | 09:38 PM
LT1Z28M6's Avatar
Re: RPM at Idle??
A4 or M6?
Old Jan 2, 2006 | 12:21 AM
Kataklysm's Avatar
Re: RPM at Idle??
If its a 6 speed manual thats about right, if it is an automatic it should be around 550.
Old Jan 2, 2006 | 12:55 AM
Bayer-Z28's Avatar
Re: RPM at Idle??
800-900 rpm is normal
Old Jan 2, 2006 | 01:33 AM
crakpotjoe's Avatar
Re: RPM at Idle??
So with my A4 sitting at 700 is that cool?
-crakpotjoe
Old Jan 2, 2006 | 08:32 AM
teke184's Avatar
Re: RPM at Idle??
with the autos, i think it is different when in park and when in drive.
700 in park or neutral sounds about right
550 in drive as well
Old Jan 2, 2006 | 09:02 AM
2001NBMZ28's Avatar
Re: RPM at Idle??
My stock A4 idle RPM's on Predator were:
P/N 645-676
D/OD 525-585
Old Jan 2, 2006 | 11:11 AM
MikeyG's Avatar
Re: RPM at Idle??
My 98 M6 car idled at 800.
My 01 A4 idles at 650 in park.
Old Jan 2, 2006 | 06:56 PM
RMC_SS_LDO's Avatar
Re: RPM at Idle??
Thought I was the only one that wondered about that.....
Always seemed like mine (A4) ran a little low in gear at a light after it warmed up (about 600). Must admit it induced a slight chubby having the car shake at idle- I thought it was just screaming for a hotter cam to really make it thump!
Allen
Old Jan 3, 2006 | 12:02 AM
TheMT1's Avatar
Re: RPM at Idle??
I've always noticed the six speeds idle higher when coasting out of gear.
Old Jan 3, 2006 | 12:17 AM
CrabhartZ28's Avatar
Re: RPM at Idle??
I believe mine at idle in drive were around 500, in park around 6 or 700.
Old Jan 3, 2006 | 12:30 AM
RedlineBrian's Avatar
Re: RPM at Idle??
I have an '02 six speed. I idle at 900 too.
Old Jan 3, 2006 | 01:21 AM
Re: RPM at Idle??
you're kidding, i only idled that high on cold starts.
Old Jan 3, 2006 | 04:50 PM
squirrelishere's Avatar
Re: RPM at Idle??
My car is usually idling at about 900. Used to be at exactly 1k, but with my new transmission, it went to 900. Seems to stay there whether in park or drive.
KYWes
Aug 4, 2015 01:54 PM
andrewcapps82
May 19, 2015 10:11 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
edman
Jan 25, 2015 02:41 PM
edman
Jan 22, 2015 02:45 PM
