Why am i losing oil?
Old Feb 12, 2006 | 04:12 PM
ponykiller z28's Avatar
ever since i bought my ls1 SS (with 20k miles on it) It has the tendancy to lose about 1-2 quarts of oil between every 3k miles. However there are absolutely no leaks anywhere, and no smoking. There is also no buildup of any oily substance on my back bumper that could be coming out the exhaust.
The engine runs like new, with great oil pressure.
Any suggestions??
Old Feb 12, 2006 | 04:46 PM
Greed4Speed's Avatar
Re: Why am i losing oil?
This is typical, even more so with 01-02 models.
Old Feb 12, 2006 | 06:53 PM
sir dyno's Avatar
What oil do you use? And yes it's normal. I changed oils and oil filter and don't have to put oil in between oil changes. But I do put in 6 quarts and i know the ls1 takes 5 and 1/2. By the why I switch to regular 5-30 valvolien the white bottle. And so far I haven't had to add oil. You can also get an oil anaylisis.
Old Feb 12, 2006 | 08:20 PM
well i only put in 5 quarts. It shows full on the stick then. i use penzoil 10w-30 then 10w-49 every other change.
Old Feb 12, 2006 | 09:15 PM
Is that full on the stick prior to cranking your engine and getting oil into the new filter?
Old Feb 12, 2006 | 10:24 PM
sir dyno's Avatar
It should be 5.5 quarts. Why you use 10w-49 every other oil chang?
Old Feb 12, 2006 | 10:46 PM
380ss's Avatar
This article will explain your problems, and show you a fix for it.
You need the LS1 to LS6 PCV conversion
read on.
http://www.ls1howto.com/index.php?article=18
Old Feb 12, 2006 | 11:21 PM
I meant to say 10w-40.
and i fill the filter before i put it on
Old Feb 16, 2006 | 11:34 AM
read on.
so that explains my problem. Thanks 380ss
Old Feb 16, 2006 | 12:07 PM
380ss's Avatar
No problem, glad I could be of help
Old Feb 16, 2006 | 05:41 PM
SFB767's Avatar
Try using 5W-30, that's what GM recommends in the instruction manual.
Old Feb 18, 2006 | 01:01 AM
sir dyno's Avatar
Thats what I use.
94Form
Jul 17, 2015 10:56 PM
Noct
Jul 14, 2015 01:18 AM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
