LS1 valve spring I.D.
Old Jan 24, 2006 | 01:09 PM
kevm14's Avatar
I may be inheriting a used set of LS1 valve springs for free, and I'm thinking about trying to make them work on my Caprice. Comp just came out with a set of beehive valve springs but they're too expensive to justify (versus a new stock set, or the like). I know LS1 springs are the beehive type.
What is the inner diameter of the top (smaller) part of the spring? Comp makes a set of retainers designed to be used with their new springs and the non-metric older style valve, as well as the older style keepers. It is my intent to find out if I can use this retainer, or if I have to figure out something else (like stock LS1 retainers with my regular SBC keepers, or try aftermarket keepers). I can tolerate a ~0.1 inch decrease in installed height, and that might be desired given the LS1 springs' low seat pressure, and my heavier valvetrain.
Thanks.
Old Jan 26, 2006 | 07:36 AM
teke184's Avatar
Re: LS1 valve spring I.D.
i'll see if i can remember to measure my springs when i get home.
i have a good set of calipers so it should be nice and accurate
DirtyDaveW
Mar 15, 2015 07:01 PM
Red_94Formula
Jan 22, 2015 12:17 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
