What gives??
Old Jan 20, 2006 | 08:52 PM
GoFast908Z's Avatar
Member
Angry What gives??
A friend just installed LTs and true duals the other day....nearly the same as mine, just minus the cats.
Here is the link to his dyno results..
http://wcgmp.com/forum/viewtopic.php?t=1731
WTF!!! I only gained 14 hp 6 ft with mine. What the hell?
Old Jan 20, 2006 | 09:15 PM
1984camaroz28's Avatar
Re: What gives??
not all headers are created equal what is ur combo and what is his
Old Jan 20, 2006 | 10:25 PM
GoFast908Z's Avatar
Member
Re: What gives??
He has Pacesetter LTs, TSP true duals, 3", moroso mufflers
I have Jet Hot LTs, random tech high flow cats, dr. gas x-pipe, all 3" mandrel, dynomax bullets
Old Jan 21, 2006 | 02:47 AM
wdtiger's Avatar
Re: What gives??
How is that nearly the same? lol.
Old Jan 21, 2006 | 03:02 AM
GoFast908Z's Avatar
Member
Re: What gives??
Both have LTs
Both have 3" true duals
Both have similar straight-through mufflers
Only difference....the cats, i have them.
Old Jan 21, 2006 | 07:11 AM
rwb's Avatar
rwb
Re: What gives??
Not all LT's are the same, not all engines respond the same, different day different weather at the dyno. It could be a lot of things.
Old Jan 21, 2006 | 08:32 AM
teke184's Avatar
Re: What gives??
cats can easily account for 5hp
and his car may have ended up with a more optimal a/f ratio after the header install, resulting in more power. while your's may have been thrown off.
or just typical variation in header design, dyno results, weather, humidity, planetary alignment....all things that make dyno numbers only usefull for internet racing
Old Jan 21, 2006 | 08:01 PM
Mike94ZLT1's Avatar
Re: What gives??
Quit bitching about it and go buy some more mods to make up for it!
Old Jan 21, 2006 | 08:53 PM
GoFast908Z's Avatar
Member
Re: What gives??
that doesn't answer the question though. It just doesnt' make sense to me.
besides, i'm short on cash right now!
Old Jan 22, 2006 | 09:14 AM
AL SS590 M6's Avatar
Moderator
Re: What gives??
His is a 99 yours is a 98
he doesn't have cats
More than likley it's all in the tune.
Get yours tuned.
Old Jan 22, 2006 | 01:58 PM
GoFast908Z's Avatar
Member
Re: What gives??
Get yours tuned.
his has not been tuned yet
why does the 98/99 comparison matter?
Old Jan 22, 2006 | 08:09 PM
Mike94ZLT1's Avatar
Re: What gives??
I believe there is a difference between the 98 and 99+ computers, perhaps the 99+ will respond to modifications better? In fact, come to think of it I know theyre different. Years ago, I would see places that would only tune 99+LS1 cars. This applies to Corvettes too.
Old Jan 23, 2006 | 07:57 AM
Will_Die_Trying's Avatar
Re: What gives??
this is simple>>>>>>>>>>>the cars were not, are not and will never be exactly the same, and no two companies' headers will ever produce the same exact hp for every car you install it on. This is all part of what modding is about.....finding what works...4 you. and remeber what works for you does not always work for others and vice versa
