Service Engine Light after spark plug change
Old Jan 20, 2006 | 10:03 AM
jm825's Avatar
I just changed my plugs and when I finished I started the car it was running rough and the engine light came on. I heard a constant ticking noise and look under the hood. One of the wires was loose. I made sure to put the wire back in tight and started it up again. It ran pretty and sounded pretty good. Every thing seems to be working fine but the light still comes on.
Any Ideas????
Old Jan 20, 2006 | 10:08 AM
teke184's Avatar
Re: Service Engine Light after spark plug change
you have to clear the code off the computer. it stores them and keeps the SES light on.
pull the battery cable for 10 mins or so...should be fine.
Old Jan 20, 2006 | 01:51 PM
snakesmoker's Avatar
it should go off in a day or two
Old Jan 20, 2006 | 05:45 PM
2001NBMZ28's Avatar
If it was a P030X (misfire) code it should turn the light off after three consecutive starts if the problem is gone, but will still stored in memory for a while.
Jazsun
Dec 29, 2014 12:14 PM
mspennyhughes
Nov 28, 2014 03:22 PM
Jul 4, 2005 05:00 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
