New dream is it to much? LS7
Old Dec 31, 2005 | 07:44 PM
LarrieuY2KSS's Avatar
Once the awsome LS7 goes on sale, what would it take to put it into a 2000 SS. Just curious of what it would take to complete this task and would it be worth it?
Old Dec 31, 2005 | 07:55 PM
angel71rs's Avatar
Re: New dream is it to much? LS7
It's going to be limited production and cost more than your SS. Have an aftermarket vendor sleeve you an LS2 block, get a rotating assembly and build your own for much less.
Old Dec 31, 2005 | 08:24 PM
teke184's Avatar
i think VRE makes a 427 short block....big nasty cam, nice AFR heads, FAST intake....
Old Jan 2, 2006 | 07:02 PM
RMC_SS_LDO's Avatar
Originally Posted by LarrieuY2KSS
Once the awsome LS7 goes on sale, what would it take to put it into a 2000 SS....
A big friggin check-book....
Old Jan 2, 2006 | 08:44 PM
CrabhartZ28's Avatar
Well gmpartsdirect.com has 4 of them. each for a cool $15,500. That's more than i payed for my 2004 truck.
Old Jan 2, 2006 | 08:54 PM
Gun5's Avatar
damn, costs as much as my whole car now..... ill be happy with my used camaro engine w/ 400 hp+ i doubt uv maxed out your current engine lol
Old Jan 3, 2006 | 08:28 AM
teke184's Avatar
how bout this...professionally installed and everything.
F-Body LS1 Extreme 427 Close
INCLUDES:
-MTI Darton resleeved block
-Billet 4.00” stroke forged crank
-Billet 6.125” connecting rods
-Diamond Custom 4.125” pistons
-Diamond Pro-select rings
-High performance bearings
-All Gaskets, seals and hardware
-Custom Comp Cams Roller camshaft
-Comp Cams Lifters
-Comp Cams chrome moly pushrods
-Double roller timing chain
-SLP blueprinted oil pump
-ASP SFI approved underdrive pulley
-RGR, MTI, Patriot, or GTP stage 3 premium cylinder heads
-GM LS6 Intake manifold
-Fully balanced/blueprinted/Finish hone w/torque plate, assembled
-Hooker coated or SLP headers
-Offroad y-pipe
- Spec stage 3X clutch
-Fidanza aluminum flywheel
-Taylor 409 Race wire 10.4mm LS1 Red
-NGK spark plugs
-Hypertech 160 Powestat
-SLP, Whisper or MTI Induction lid
-SLP high flow bellows
-High flow 30# Injectors
-Everything Professionally Installed
-Fully Professionally Dynotuned
$15,999 or
$17,999 with 2 year limited warranty
Speed Inc.
Old Jan 3, 2006 | 08:58 AM
Eric@Victory Racing's Avatar
Callies Racemaster Crankshaft
Calles LS1 I-Beam Rods 6.125"
Diamond Custom Pistons
Diamond Pro Select Rings
ET Perforamnce CNC Cylinder Heads
F.A.S.T 90mm Intake
F.A.S.T 90mm Throttle Body
Morel Hydraulic Lifters
GM Production Rocker Arms
Cometic MLS Head Gaskets
VRE Custom Spec Camshaft
Meling LS6 Oil Pump
Adjustable Timing Set
Chromemoly Pushrods
Clevite Rod Bearings
Clevite Main Bearings
Clevite Camshaft Bearings
ARP Main Studs
ARP Head Studs
Fully Machined Block w/Deck Plates
Blueprint and Assemble
$14,000.00
Old Jan 3, 2006 | 10:09 AM
What would I expect on average at the rear wheels on power output with any one of those 427 set ups. just curiuos of the lowest output to the most extreme output. Also I do most of my driving on the street so of course I want to retain a streetable car but be able to eat anything on the street and track!
Old Jan 3, 2006 | 10:47 AM
With an M6 car 550rwhp is pretty reasonable.
Old Jan 3, 2006 | 10:50 AM
Would it be wise to upgrade to a 12 bolt for safety measures?
Old Jan 3, 2006 | 11:07 AM
redzsmoked212's Avatar
hell yes it would be a good investment to add a 12 bolt.
silly billy i cant see you going to far with the stock rear end and that much power.
Old Jan 4, 2006 | 01:28 AM
Thats affirmative, some kind of aftermarket rear end will be neccesary. I'd say a 12 bolt with a posi unit and 33 spline axles would fit the bill nicely.
Old Jan 4, 2006 | 06:16 AM
teke184's Avatar
Nick
you've helped me in the past with some info...so i don't want to sound like i'm trash talking you.
but the site i listed was installed and dynotuned....not sure if your price is or not. granted $2000 is alot for installation of an engine and dynotuning, but still.
although i see your setup includes the FAST intake...which is pretty sweet and i'm sure is great on such a big cube motor.
Old Jan 4, 2006 | 06:36 AM
Our price was not installed or dyno tuned but we do chage less than $2,000 for those services.Also we are not comparing apples to apples with these to packages. I am not saying there is anything wrong with their engine package but we have some upgraded parts in ours that unfortunately ups the price. We have a Callies Racemaster crankshaft instead of Eagle 4340,Callies I-Beam Rods instead of Eagle H-Beam, F.A.S.T 90mm intake instead of LS6,and so on.
Originally Posted by teke184
Nick
