98-99 00-02 power difference?
Old Dec 23, 2005 | 10:09 AM
quicksix956's Avatar
Is there a difference in power between the 98-99 ls1 and the 00-02 ls1? If you order headers why are they different for the 00-02 then 98-99?
Old Dec 23, 2005 | 10:29 AM
Capn Pete's Avatar
Re: 98-99 00-02 power difference?
They got rid of the EGR system in 2000. In '01/'02, they also started using the LS6 intake manifold and a slightly different camshaft (less lift, but altered duration). At the end of the day, ALL LS1's are within a few HP +/- of each other. Mine's an '02 and dyno'd 289 HP at the wheels, while others (typically M6's) have dyno'd upwards of ~320 at the wheels stock! There is, on average, a tendancy for '01/'02 cars to dyno a little higher than '98-'00, but that's because of the intake/cam change.
However, no matter how you look at it, an LS1 is an LS1 ... they kick a$$.
Old Dec 23, 2005 | 11:52 AM
00cls1camaross's Avatar
dont your gears make your dyno less?
Old Dec 23, 2005 | 12:23 PM
MasterEvilAce's Avatar
I'm pretty sure gears don't change your HP at all.. it just makes the engine able to work a little easier
Old Dec 23, 2005 | 12:56 PM
Aaron91RS's Avatar
98's had a different ECM and injectors.
From just reading camaro boards all day I noticed they seem to actually be a little faster then the 99's on average.
Old Dec 23, 2005 | 04:03 PM
Capn Pete's Avatar
Yeah, the 98's used 28lb injectors, 99+ all used 26lb AFAIK.
I've read more than once where people claim that low gear ratios "kill" dyno #'s, but I think that's more of a myth than fact? Stalls absolutely kill the #'s, but gears? Nah.
Just do the math (let's figure ~15% loss for my auto) ---
289 RWHP / .85 = 340 flywheel HP (not far off, but what if there's more loss?)
289 RWHP / .82 = 352 flywheel HP (using 18% loss, that looks good )
Really, how much power does a lid and a Flowmaster (a.k.a. "Choke-master") really add? I'm satisfied to say my LS1 is making a true 350 HP.
Old Dec 23, 2005 | 04:17 PM
DrewSG's Avatar
They got rid of EGR in 2001 with the LS6 intake, not 2000
Old Dec 24, 2005 | 02:03 AM
RussStang's Avatar
Correct.
Also, going with a lower gear, which is numerically a higher gear, to keep some of you from getting confused (i.e. 4.11s are a lower gear than a 3.23), there is typically a slight loss in power to the wheels on the dyno. I would hardly say gears kill dyno numbers though.
Old Dec 24, 2005 | 05:57 AM
SFB767's Avatar
If you were to test drive well-maintained LS1s ranging from '98-'02 without knowing their model years beforehand, you probably wouldn't be able to tell the difference in performance.
Old Dec 24, 2005 | 02:53 PM
RussStang's Avatar
01s and 02s WILL dyno slightly higher if you look at average power numbers given each model. There is a reason the LS6 intake manifold is favored over the LS1 manifold. The 01s and 02s did get a truck cam grind, but the LS6 intake manifold more than makes up for the power the came may cost.
Old Dec 26, 2005 | 04:14 PM
StudyTime's Avatar
I can't offer any proof as to how it happens sadly, but I do know it's not a myth. Steeper gears will take power away on the dyno.
Ben T.
Old Dec 26, 2005 | 05:17 PM
RussStang's Avatar
Ben T.
Steeper gears more than make up for any hp they might consume at the wheels, but you are correct.
Jan 23, 2015 01:13 PM
InfernalVortex
Jan 17, 2015 09:35 AM
XtremeLt1
Sep 13, 2002 08:50 PM
