FAST 90/90....what are they doing about the 75mm maf?
Old Jan 9, 2006 | 08:59 AM
teke184's Avatar
so for those guys putting the big boy FAST 90/90 combo on thier cars. are you upgrading your MAF sensor as well?
everyone always talks of the stock maf not being a restriction, but that is on the factory 75mm TB and intake opening.
to take advantage of the bigger FAST setup, is a bigger maf needed? like the ZO6 or similar?
you also hear the tuning can be a pain with these, does it become easier with such a radical setup? or is it just an accepted hassle in building such a motor?
what are the LS7s using for a MAF?
Old Jan 9, 2006 | 07:48 PM
myslowcamaro's Avatar
Re: FAST 90/90....what are they doing about the 75mm maf?
im in the process of getting a maf for that exact setup. still researching pros/cons to other maf's and what tuning needs to be done. keep in touch on it.
Old Jan 9, 2006 | 09:13 PM
TransAmAbe's Avatar
And what about the lid/bellows on these setups? If you get a FAST 90/90 and larger/ported MAF, aren't you still restricted by the lid and/or bellows at that point? Short of doing something like a Ramjet style manifold with a big honkin' K&N sticking off the front...
I always wondered what the point of spending the money on the larger MAF was if your lid and bellows are the same size. Obviously the FAST stuff doesn't flow in just a straight line so I see the improved efficiency with that.
Abe
Old Jan 10, 2006 | 06:21 AM
teke184's Avatar
TSP use to offer a lid with an 85mm opening.
although i think the opening on standard lids is still more than the diameter of the stock maf. so it's not that much of a restriction.
Old Jan 10, 2006 | 10:01 AM
AL SS590 M6's Avatar
Moderator
Abe
Get out a measuring tape. The opening on the lid is big enough you just have to butt the large MAF rather than sliding it inside. Then you need a larger soft rubber pipe between the MAF and throttle body.
Texas Speed also makes a lid for the 85mm MAF if you want to go that way.
Old Jan 26, 2006 | 11:24 AM
teke184's Avatar
come on i know some guys on here have the FAST intake...more input?
Old Jan 26, 2006 | 12:07 PM
PAGregSS's Avatar
Fast Toys is going to be making a new lid with a 90mm opening. Many of the 90/90 guys are actually running without a MAF. It's all in the tuning.
Old Jan 26, 2006 | 06:17 PM
ive heard that before. something about a vre file that backs up the maf calibration if it ever got corrupted.
teke, im probably just going to use the 85mm lid and maf myself.
Old Jan 27, 2006 | 12:31 AM
Drew778/94Z's Avatar
I'm running FAST 90 intake and NW TB with an SLP lid and stock MAF and still gained 1.5 mph in the 1/4 over my LS6 intake and Shaner 2 TB.
Old Jan 27, 2006 | 05:41 AM
teke184's Avatar
interesting.
have you thought of swapping to a bigger maf to see what happens?
seems kindda stupid to spend $1200 on intake/tb and have it restricted by the maf sensor.
not to mention only gaining 1.5mph seems pretty small for the price too
Old Jan 27, 2006 | 09:32 PM
Drew778's Avatar
Originally Posted by teke184
interesting.
I had a Pace LS-6 vv MAF before and went back to stock after tuning issues with MS3 cam.
Not really, you spend more then $1200 on a heads swap to only gain 15-20 hp, but I am thinking of plastic MAF ends for more flow and less heat.
I also have done no tuning for the FAST 90/90 with tuning I'm sure I can pick up more.
Old Jan 27, 2006 | 11:08 PM
teke184's Avatar
whoah..did you change screen names?
i'll be in touch
Old Jan 28, 2006 | 12:38 AM
Drew778's Avatar
i'll be in touch
I haven't posted in a while and it had me change some things?
AtlasXVIII
Sep 7, 2015 03:39 PM
colts0455
Sep 2, 2015 12:41 PM
95blkss
Parts Wanted
Jul 19, 2015 08:42 PM
Noct
Jul 14, 2015 01:18 AM
