98 LS1 lifespan?
Old Jan 2, 2006 | 09:45 AM
brians96Z's Avatar
98 LS1 lifespan?
After reading some about the 98 LS1's having a "weaker" oil pump than the later models, I was just wondering. How many of you out there have actually had one fail in your 98? Anyone have a 98 that is holding up well over 100K? I know the motor is up to it, I am just basically addressing the oil pump issue.
Old Jan 2, 2006 | 11:15 AM
Kwiksilverz28's Avatar
Re: 98 LS1 lifespan?
Replace the oil pump if it worries you. It doesn't me, but if I ever do a cam swap, I will replace it....
Old Jan 2, 2006 | 12:59 PM
BandDirector Blk98ZM6's Avatar
I replaced my '98 LS1 after 73K miles with an LS6 longblock. It started knocking...I have no idea why and it's still sitting on a stand in my garage and I never opened it up to check. I did the swap in July of '04.
Old Jan 5, 2006 | 06:37 PM
1984camaroz28's Avatar
It will last aslong as u take care if it there are a few 98 ls1 with 150k still runing strong
Old Jan 12, 2006 | 06:36 PM
StealthZ28's Avatar
The only thing I had to replace was my water pump on my '98Z. Other than that, I haven't any other problems.
Old Jan 15, 2006 | 12:20 PM
9T8W66's Avatar
I have a `98 with 105K and all I've done is replace the water pump at 88K
Oh Ya and I am still running the original clutch.
Old Jan 15, 2006 | 06:36 PM
slackerr's Avatar
My 98 has 74k with over 100 passes with the stock oil pump & I shift it at 6800.
Old Jan 16, 2006 | 12:14 PM
Royalmar's Avatar
Just passed 120k on my 98 LS1 in the AZ summer heat. Only thing changed was water pump at 80k. Still have good oil pressure.
Old Jan 16, 2006 | 12:22 PM
LT-14me's Avatar
my LS1 has 87k miles on it and i have had to replace the alt. the thermostat and the clutch, and an seal near the knock sensor (dealer did it nice 800 bucks!) Other then that though she hasnt left me walking.
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
1slow93z28
Sep 1, 2015 06:22 PM
