ls1 block integrity
Old Jan 27, 2006 | 10:29 PM
SnoFox's Avatar
ls1 block integrity
how strong is the ls1 block? if i were to go like 427 stroker would i run into block integrity issues? i havent seen any big cube ls1's and was wondering if this is y, thnx
Old Jan 28, 2006 | 05:26 PM
Kraest's Avatar
Retired
Re: ls1 block integrity
You won't see that many cubes on an LS1 block even if you had it resleeved.
Your best bet is a 6.0L truck block or an LS2 to achieve those goals.
Mike
Old Jan 28, 2006 | 06:16 PM
JJEXP's Avatar
The c5r race block is another good option
Old Jan 29, 2006 | 05:38 AM
Eric@Victory Racing's Avatar
Victory Lane 427ci Longblock
Compstar M.I.D. Block
Compstar 6.125" LS1 Rods
Callies Racemaster 4.000" Crankshaft
Diamond Custom Pistons
Diamond Pro Select Rings
ET Perforamnce CNC Cylinder Heads
Comp Cams Hydraulic Lifters
GM Production Rocker Arms
Cometic MLS Head Gaskets
VRE Custom Spec Camshaft
Meling High Volume Oil Pump
Adjustable Timing Set
Chromemoly Pushrods
Clevite Rod Bearings
Clevite Main Bearings
Clevite Camshaft Bearings
ARP Main Studs
ARP Head Studs
Old Jan 29, 2006 | 08:59 AM
Plague's Avatar
A guy at work had his ls6 block bored to be a 427 at a place in houston. But, I will not post where b/c they do not support this forum. If you want to know, you can pm me. But, victory racing is a good company that I have heard nothing but great things about.
Sergio
Jan 27, 2016 04:27 PM
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
R@mpage
Apr 20, 2015 10:02 AM
CARiD
Jan 27, 2015 06:27 AM
