ls2 oil pan
Old Feb 2, 2006 | 09:46 AM
Will_Die_Trying's Avatar
ls2 oil pan
I have read that the ls2 has a improved dry sump oil pan, for the corvette, what about the gto? any improvements to keep for lack of oil on cornering?
Also does this propblem exist in the fbody ls1, if so, is there an upgrade in the ls1 fbody that can help with this?
Old Feb 2, 2006 | 08:22 PM
cabell84's Avatar
Re: ls2 oil pan
Not too sure if its a real problem or not on the LS1, but I think you can get a baffled oil pan to alleviate some concern about it. Not sure, but I think I have seen one somewhere.
Old Feb 3, 2006 | 08:12 AM
Victory Racing's Avatar
Re: ls2 oil pan
Melling makes a High Volume pump for the LS1/2 engines. It has a larger inner gear and thus moves more oil, and it also has an stiffer spring in it to regulate the pump valve.
As for the dry sump, the LS7 in the new Z06 is a dry sump but not the LS2.
Old Feb 3, 2006 | 11:54 AM
Re: ls2 oil pan
can you converet an ls1 to an ls2/ls7
can you convert and ls1 to a dry sump to prevent oil shortage in tight corners.
Old Feb 3, 2006 | 03:49 PM
Greed4Speed's Avatar
Re: ls2 oil pan
I'm sure someone has a dry sump kit, but all you really need are baffles or just run a quart extra when racing. Unless you are seriously into road racing, you'll never have that problem. Even then, I haven't notice any of the LS1 guys that race running dry sumps. Must not be an issue.
Old Feb 4, 2006 | 07:34 AM
Re: ls2 oil pan
http://www.drysump.com
That is the website for Armstrong Racing Equipment, great stuff and great people to work with.
HectorM52
Jul 30, 2017 11:46 AM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Elcojoe
Nov 17, 2014 10:27 PM
