which pulley to get?
Old Feb 17, 2006 | 04:40 PM
ls1650's Avatar
hey guys there are many different types of pulleys out there. for example, ASP Harmonic Balancer Crank Pulley, ASP Overdrive Alternator Pulley, ASP Underdrive Alternator Pulley, and Powerbond 25% Underdrive Crankshaft. which one is required to get and which one is not necessary? also are belts a requirement to get when you buy a pulley? thanks for the info.
Old Feb 18, 2006 | 09:05 AM
teke184's Avatar
Re: which pulley to get?
any of the underdrive pulleys are gonna be the same. the pulley taht goes on the alternator is to reduce the chance of voltage lose due to the alternator spinning slower with the underdrive crank pulley.
you want the overdrive alt pulley if you get it.
the underdrive crank will spin the accessories less and free up some horsepower. you don't have to get the alternator pulley, but if you run a stereo system you'll probably want it
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
