ls6 heads
Re: ls6 heads
Originally Posted by LarrieuY2KSS
when you say "a lot more" how much is that? aslo what cam would prove "a lot more" power with ported LS6 heads?
Re: ls6 heads
off kraests sig? it means that since he is going to have a 470+ rwhp car, when he drives it he is going to take a poo poo in his pants. Since, **** is brown, you will need brown pants so no one can see his accident!
Re: ls6 heads
stock ls6 heads on a stock cam....10-15hp...maybe.
for cams, what kind of power levels are you looking for? with the LS1 you can easily make good power with just a cam swap. how much drivability are you willing to sacrifice?
Re: ls6 heads
If you have a large cam you'd need larger ports and valves.
Stock or smaller cam smaller valves and ports.
Performance wise? Depends on what you have and what you decide to go with. Go large heads on a stock cam and it'll kill your low RPM and not do a whole lot for you up top either.
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
hotrodyou1
Dec 20, 2014 10:05 PM
