Direct-Flo lid, mine doesn't fit!
I thought I did some sound research deciding which air lid would be best for my '01 WS6 Trans Am. I called LS1 Motorsports and ordered (2) Direct-Flo lids, which were $95 ea. Having one for my 01 and another for my cousin's 02 WS6, they arrived yesterday. Trying to get these things on is a JOKE! The 4 tabs at the rear don't even come CLOSE to fitting in the holes. The problem appears to be the outlet of the lid itself is resting on the radiator shroud. I can get it installed and clamped with the tabs sitting on top of their holes but then I see exposed filter which will create air leak and we all know that's not good.
What's up with these air lids??? Anyone else have a problem getting they're Direct-Flo lid to fit? No way will they take it back, I opened the box to find a couple letters peeling off so I removed them and replaced it with a "Ram Air" decal.
Any tips on getting this thing installed???
Its hard to install the first time. After that, you will be able to put it on and take it off with no problem. Struggle some more, feed the tabs into the holes..it will go. Don't run it without the tabs engaged or it will leak. Good luck.
Red 02 SS, chrome 10's, black leather, t-tops, M6, stock exhaust, lid, and fast as hell!
Right on man!!
I just installed the same lid on my car a week ago, and at first I was like "is this a f'ing joke?!"
- especially when the "instructions" read: may be "a little tight" when installing for the first time. Also, I had a couple letters that were sort of peeling off mine too --- for the cost of the thing ($200 Canadian) I would have liked a little better than peeling decals and a nearly-impossible fit!
But oh well, it's on now right?!
NOTE: to anyone else installing a new lid (LS1 Motorsports "Direct-Flo" lid in particular) it is a Pain In The ROYAL A$$ the FIRST time you try to install it --- but be patient, and "gently forceful", and it WILL GO!!!!!
Once it had been on for a couple days though, it came off and went back on easily.
2002 Z28 - A4, 2.73's, Blk/blk, leather, T-tops, sport appearance package - just bought on June 26, 2002! - Pics
1981 Z28 - 383, TH350 trans., 3.42 posi - sold August, 2000 - Pics
1973 Camaro - Dad's & my project in the works - to be built: 355 Chevy, 11.5:1 pop-ups, "camel hump" heads (w/2.02 valves), solid cam, 4-speed.....it should be quick! - Pics
Once it had been on for a couple days though, it came off and went back on easily.------------------
Must just be direct-flows, my whisper lid went on pretty easy.
'02 Red Z28, ebony leather, M6, T-tops, Trac. cont., hurst shifter
Borla (the expensive cut-out), Wisperlid W/K&N, FRA, Cags eliminator, Strange 4.10's, G2 Rear Girdle, Valv. Synthetic 10W-30, Redline gear oil, Fat hurst shift ****, Lead foot
Soon to be:
Alpine Screen, Orion xtr 800.4, xtrpro 1000, Kicker 12L7 in a milhouse, Focal polykev K2's, Focal utopia 6" audiom midrange.
Soon to be:
ericinsd
Jul 31, 2002 02:15 PM
Chrisdude
Jul 25, 2002 05:54 PM
Chrisdude
Jul 24, 2002 02:25 PM
