LS1 Computer
Old Sep 6, 2002 | 10:09 PM
Topform11's Avatar
Post LS1 Computer
I was wondering what you can do to reprogram the computer in a 02 Z28. I heard that there was a program that you could put on your laptop and reprogram the computer. Also the car off the line is kind of slow. but when the RPM's get up there is boogies. It only has a 323 gear. I was thinking of putting a 393 in it. Is this wise or is this a bad idea. Also what would you reccomend to make the car a little quicker off the line. Thanks Rick
Old Sep 6, 2002 | 10:26 PM
rncotton's Avatar
Post
The program you refer to is "LS1 Edit". I'm sure someone will post a link. I think it's carputing.com but not sure.
As for the gearing ... you running M6 or A4 ?
If you're running an A4, a torque converter will be your best option for "off the line". Combine a 3000 stall converter with 3.42 (3.73 if you've got big *****) and you'll have a huge hole shot.
If you're running a M6 ... 4.10 will get you a nice increase of off the line performance.
2001 TransAm WS6, M6 3.42
HPP, TBB, 160* t-stat, MTI Lid, Holley PowerShot, Flowmaster 80, Port/Polish MAF, !CAGS
www.BlackWS6.com
2001 Z28
-- R.I.P. - 06/25/02
[This message has been edited by rncotton (edited September 06, 2002).]
Old Sep 6, 2002 | 10:39 PM
Capn Pete's Avatar
Post
Obviously since you say you've got 3.23's, your car is an Auto. Changing gears will definitely change the way your car performs --- especially in the SOTP feel!! 3.73's are supposed to be a really nice gear for autos - I've had an auto with 3.42's before, and that was a nice combo, but 3.73's are supposed to be that much "snappier". You mentioned 3.93's though --- either you meant 3.73's, or they're just not a common gear?? Regardless, lowering the gears in your car will definitely change the way it feels and performs.
In regards to computer programming: LS1 Edit is certainly one way to read and change the programming of your computer (probably the best??). There are also aftermarket programmers that simply plug-in to your car (Hypertech Power Programmer - HPP) that allow you to change certain parameters, but don't allow as much fine tuning as LS1 Edit (which plugs in via a laptop computer).
Good luck with your modding!
2002 Z28 - A4, 2.73's, Blk/blk, leather, T-tops, sport appearance package - just bought on June 26, 2002! - Pics
1981 Z28 - 383, TH350 trans., 3.42 posi - sold August, 2000 - Pics
1973 Camaro - Dad's & my project in the works - to be built: 355 Chevy, 11.5:1 pop-ups, "camel hump" heads (w/2.02 valves), solid cam, 4-speed.....it should be quick! - Pics
Aneurysm's Avatar
Arrow
Yeah just in case you didn't know LS1's are famous for top end, above 3000 or so. People say the LT1 owns the bottom end.
And that link is correct, it's www.carputing.com although it's rather expensive, $550 US dollars. There are other LS1 edit programs available for cheaper, but LS1 edit is the best.
2001 Camaro SS #C095 RCS Secret Street #R675
Light Pewter Metallic
M6, T-Tops, Ebony Leather
Appearance: Alpena Pedals, 15% Tint (Side & Rear), SLP Car Cover.
1slow93z28
Sep 1, 2015 06:22 PM
Nickster 7
Aug 27, 2015 10:12 PM
350350
14
Aug 11, 2015 12:03 PM
Jocofire1
Aug 7, 2015 03:16 PM
mrwz28
Jul 8, 2015 09:11 PM
