Next power mods? hotcam/heads?
Old Sep 16, 2002 | 01:01 PM
DohHunter's Avatar
In the spring i'll be looking to do a little modding.
Now i'm going to go headers/Y-pipe for sure......and I would like to start internals with a cam.
Anyone have any experiance with the LS1 Hotcam kit? install time? etc.?
Can I put in the cam without changing heads right away.......i might be on a bit of a budget.
I also know Thunder Racing sells some good cam kits........I wanted something streetable but you would still know its there
Old Sep 16, 2002 | 01:25 PM
CPFarhood's Avatar
Stock heads are fine for a hotcam. Also for the power gains a HotCam kit is a great deal. Only thing i was wondering when doing a hotcam is will the stock fuel system support it?
Old Sep 16, 2002 | 01:30 PM
DohHunter's Avatar
Thanks for the reply.
So if I just install the hotcam kit, any other engine upgrades required?
Old Sep 16, 2002 | 01:37 PM
CPFarhood's Avatar
If you have an auto it will need to be tuned, a tuning is recommended either way, but for an auto it's pretty much required.
Old Sep 16, 2002 | 05:25 PM
redz_02's Avatar
i dont think they are realy required but if you want full potential then you should get some LT's, a bigger MAF, and a bigger throttle body. The stock ls1 heads flow very well for a stock car, and run great with a stock cam. However, if you are looking into getting heads later on i would find a cam that is designed for a sertain set of heads. The hotcam is maid for stock heads. You may look into the hammer cam it is a little more aggressive than the hotcam.
TitoPR221
May 26, 2015 12:20 AM
Russ95Z28
Apr 23, 2015 01:55 PM
Alucard
Jul 29, 2002 10:30 PM
