whining, whinding sound
Old Jul 21, 2006 | 11:44 PM
maro z28's Avatar
This sound is noticable, especially when I'm slowing down and the engine isn't as loud. Just got the mods in my sig installed a few days ago. Has anyone had this experience? It didn't make that sound before the mods, so it has to be attributed to one of em. Especially when I'm slowing down it sounds like something is whinding down. There is a faint whining sound most of the time, just not as audible over the engine noise. Is something wrong? What can I do to stop it, because it's aggravating as hell!!
Old Jul 22, 2006 | 12:13 AM
chevychick395's Avatar
Re: whining, whinding sound
sounds like the gears you put in have a little too much backlash or not enough pinion preload. fuel pumps have been known to whine as well.
Old Jul 22, 2006 | 12:31 AM
maro z28's Avatar
Will this noise, if it is the gears or pump, eventually go away or get quieter? Is this something that needs to be fixed for reasons other than annoyance?
Old Jul 22, 2006 | 04:39 AM
Capn Pete's Avatar
Let me guess ..... Richmond 3.73's?
If the whining is just faint (noticeable, but not really bad) then consider yourself lucky. When I had my Richmond 3.73's, sounded like I had an ambulance chasing me at all speeds above ~10?! Chances are your installation is perfect, just the nature of the beast it seems.
Old Jul 22, 2006 | 05:01 AM
maro z28's Avatar
yep, Richmond
Old Jul 22, 2006 | 05:09 AM
GriffinZ28's Avatar
I've heard of Richmonds doin this, but after they settle in it will get better.
Old Jul 22, 2006 | 10:02 AM
Capn Pete's Avatar
Don't count on it. Maybe if you're lucky.
Old Jul 22, 2006 | 03:31 PM
Richmonds are notorious for the whining. Sometimes it settles most time it doesnt. Next time you do gears use the power transfer parts... ironically made by richmond however they dont whine.
Old Jul 22, 2006 | 09:01 PM
Capn Pete's Avatar
Just for the record:
My Richmond 3.73's whined BAD all the time, while my Richmond 4.10's were barely audible, and under acceleration only .
Old Jul 28, 2006 | 12:09 AM
1racerdude's Avatar
They whine but if excessive the a rule of thumb is whining on acceleration is too tight, whining on decel they are too loose on the backlash or the pinion depth isn't right
PopoFormula
Oct 12, 2015 04:19 PM
4586
Sep 27, 2015 01:55 PM
autoxr166
Sep 25, 2015 04:21 PM
cristian1311
Sep 12, 2015 08:16 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
