Oil
Old Aug 21, 2006 | 10:01 AM
skifast87's Avatar
Oil
so i still dont have a manual. I need to change the oil in my car and i need to know how much oil an LS1 takes
Old Aug 21, 2006 | 10:15 AM
psychocabbage's Avatar
Re: Oil
Since I got the car, I always put 6qts in..
The manual will tell you a tad less.. Like 5.5.. but if you drive it hard and take some serious turns (I auto X as well) 6qts is best.
I use AC Delco or Mobil 1 filters and I only use Mobil 1 5w30 oil. Walmart has the 5qt bottle for $21. I get 2 at a time.
Old Aug 21, 2006 | 10:47 AM
Greed4Speed's Avatar
Re: Oil
When the dipstick says its full, stop adding.
Old Aug 21, 2006 | 12:06 PM
skifast87's Avatar
Re: Oil
ok so 5.5 to 6 thanks guys
Old Aug 21, 2006 | 12:14 PM
Bayer-Z28's Avatar
Re: Oil
I do 5.5... Right up to the mark.
Old Aug 21, 2006 | 09:25 PM
Plague's Avatar
Re: Oil
5.5 by the books. everyone who uses 6 doesnt seem to have problems.
Old Aug 22, 2006 | 05:45 AM
teke184's Avatar
Re: Oil
i've always put the slightly larger oil filter from the 6.0L trucks on my car...and added 6qts.
Old Aug 22, 2006 | 06:11 AM
Need4Camaro's Avatar
Re: Oil
Erhm, I've actually only been putting 5 in but my dipstick is well into the "okay" range...
Curious about filters...
How are PureOne Oil Filters?
Old Aug 22, 2006 | 06:16 AM
davidz28guy's Avatar
Re: Oil
this topic is, well, wow, yea the dipstick will tell you when its full, no car is exactly the same, thats why there is a dipstick, buy 6 qts and youll prolly have a little extra for later
Old Aug 22, 2006 | 05:20 PM
00cls1camaross's Avatar
Re: Oil
i just put in 0w 30 GC and my oil pressure dropped like 7 psi at idle to almost 20 psi then again it is 110 here
mobile one it never went below 25 in the cooler weather if that made a difference...
i used K&N gold oil filters.... figure why not go to the best
Old Aug 22, 2006 | 06:30 PM
Re: Oil
0W 30 would be relatively thin, did you use that weight before and why would you in AZ???
Old Aug 22, 2006 | 10:01 PM
Re: Oil
yeah i was in new mexico... but still...
i hear the folks on LS1tech talk about it like its gold... for my car it is not... ohh well
Old Aug 22, 2006 | 10:33 PM
Tyler_LS1's Avatar
Re: Oil
i put 6 quarts of Valvoline HIGH performace 10W-30 in mine and it runs GREAT!
Old Aug 23, 2006 | 01:39 AM
Harry J's Avatar
Re: Oil
I've used 6 quarts of Mobil 1 synthetic since I've had the car and haven't had any problems.
Old Aug 23, 2006 | 09:58 AM
AL SS590 M6's Avatar
Moderator
Re: Oil
All of these motors hold exactly the same amount of oil. The difference in how much you need to refill after an oil change is due to 2 factors.
1. How much of the old oil comes out. Motor hot or cold. Angle of car. How long you let it drain.
2. What filter. Stock or longer.
Change it cold with the car tipped up from the drivers side use a stock size filter and you're in a hurry, 5 quarts could fill it.
Change it hot with the nose up do something else for a while as the oil is draining use a longer filter, 6 quarts to get to the full line.
That's your variation.
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
