in addition to whining noise on stock??!?!?!?
Old Jul 22, 2006 | 08:37 PM
jalb's Avatar
my car has been doing that,,,it sounds like a saw or a sander the faster i go such on the interstate or highway at speeds of 60-80mph its loud could it be my rear end going bad also when i put the car in gear i hear a popping noise from under the car i know its not the trans (a4) cause it dont always make the noise until i pull out PLEASE HELP
IF THE CAR ISNT STOCK I DIDNT PUT IT THERE
Old Jul 23, 2006 | 01:06 AM
mmmchickenboy's Avatar
Re: in addition to whining noise on stock??!?!?!?
maybe rear transmission mount, or a universal joint. those are easy things to check.
Old Jul 23, 2006 | 08:33 AM
AL SS590 M6's Avatar
Moderator
Originally Posted by mmmchickenboy
or a universal joint. .
Yep
Old Jul 23, 2006 | 12:11 PM
SSpdDmon's Avatar
If the whine is RPM dependent (rises and falls with the RPMs), it could be your trans pump. Incorrect line pressures will definitely affect your shifting (like when you put it in gear). If it's MPH dependent (rises and falls along with MPH), then it's on the mechanical side - so look at the parts mentioned above.
Old Jul 27, 2006 | 04:09 PM
steelerfan's Avatar
I had that same thing happen to mine,turned out to be the rear pinion bearings.Cost me $500 to get it fixed.There's evidently a problem with some of them cause I called Chevrolet & complained & they re-imbursed me the cost of the repair !
oldschool
Feb 9, 2016 09:21 PM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
ddr698
Jan 9, 2015 10:05 AM
