Help with water pump install??
Old Aug 19, 2006 | 07:55 PM
touch109's Avatar
Exclamation Help with water pump install??
I just bought an ac delco water pump and need help installing it. Does anyone have any easy way to get this done... thanks
Old Aug 20, 2006 | 05:32 AM
AL SS590 M6's Avatar
Moderator
Re: Help with water pump install??
There's no hard way to do it. 4 bolts and 4 water hoses.
I'd pull the lid, MAF, & bellows off. Remove the belt. Drain the coolant from the radiator. Unhook the hoses then change it out.
Old Aug 20, 2006 | 09:56 AM
DaddySS's Avatar
Look at LS1howto on the cam install and the water pump is part of that.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
