O2 sensors malfunction
Old Aug 3, 2006 | 07:40 AM
Boomer_Z/28's Avatar
Just got my hooker lt's in and threw a few codes on my 99 z/28.
p154- o2 sensor system no power
p155- o2 sensor system malfunction
I do have o2 sims for the back pair, and everything is plugged in. Is it possible the o2 sensors have already gone bad? They are the originals.
Old Aug 3, 2006 | 03:28 PM
2000GTP's Avatar
Re: O2 sensors malfunction
If your headers are coated, then it is possible that the sensors are now defective. For whatever reason, it seems the coating is pretty hard on the 02 sensors upon initial startup. I trashed both of my original sensors after installing my headers. Its usually a given that they will fail so alot of people will just drive around with them for a couple of days, and then replace them with a brand new pair.
Old Aug 3, 2006 | 08:14 PM
Ah i see. Forgot to mention they are coated. My bad
If both of them are out, is it affecting the performance of the car in any way? Or is it just gonna light up the ses? And what are the recommended replacement sensors?
Old Aug 4, 2006 | 08:37 AM
AL SS590 M6's Avatar
Moderator
Make sure what sensors these codes refer to ( bank 1 or 2, sensor 1 or 2)before just changing stuff out. It could be just a bad O2 simm.
Old Aug 4, 2006 | 09:01 PM
bank 2 is what it says. i believe that is the right side, yes?
any recommends on what sensors to get? Like after market or stock?
Old Apr 22, 2007 | 02:43 PM
chevytuned's Avatar
I just had the same problem. I have long tug coted headers I drove it for about a week then the light came on I pluged in the computer and it says sensor 2 low voltedge is this the same problem? or is this some thing else? thanks Jason
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
