electric water pumps???
Old Jul 14, 2006 | 11:02 PM
maro z28's Avatar
I have question about elec. water pumps for my 02z28. Will I need electric fan(s)? Meziere advertises that their elec. pumps will not require you to change your serpentine belt. wtf? I thought the whole point was to decrease the work load of your engine therefor increasing hp. What do electric water pumps use to run? A battery operated motor, your alternator, a belt? I need general knowledge about this mod please.
Old Jul 15, 2006 | 01:23 AM
Capn Pete's Avatar
Re: electric water pumps???
Dude, you already HAVE electric fans! (2, to be exact). An electric water pump will be a draw on the electrical system (it'll put more load on your alternator) but the pulley turning the water pump will be free'd up, and I imagine there is probaby "slightly" more power to be gained than there would be lost? (although the parasitic loss difference could be negligable?? ). I think electric pumps are as much to do with keeping the engine cool while idling as much as they are for freeing up power though. There was another thread talking about electric pumps recently, and I know someone said their advantage is they're always running the same speed, whether idling or full throttle, as compared to conventional water pumps that vary with engine RPM.
Old Jul 15, 2006 | 08:35 AM
AL SS590 M6's Avatar
Moderator
Meziere puts an idler pulley on the front of the pump so that the stock serpentine will still work. If you'd look under the hood of your car you'd know why.
Old Jul 15, 2006 | 11:31 AM
maro z28's Avatar
I'm aware of what's under my hood. I just didn't know if Meziere had a free spinning pulley on the front of the pump or not. The question still stands, do these pumps run off of your alternator or an electric motor you have to buy seperately?
Old Jul 15, 2006 | 11:34 AM
teke184's Avatar
hm...does an electric water pump run on an electric motor
nope they run on an exhaust driven turbine...kindda like a turbo.
not to be really rude, but if you have to ask questions like these...you need to do ALOT more research, reading, and NOT be modding your car yet.
Old Jul 15, 2006 | 01:34 PM
maro z28's Avatar
I'm dissappointed in you teke. you've always given good advice, at least to me, and never talked down to me.
Old Jul 15, 2006 | 02:06 PM
teke184's Avatar
sorry crappy mood....got a little sarcastic
maybe it was just the way you were asking the questions...
the electric water pump is that...a pump, driven by an electric motor, that is all built into one unit.
it is electric...so it runs on 12v power, which would be drawn from the battery which is charged by the alternator.
does that help?
Old Jul 15, 2006 | 03:45 PM
maro z28's Avatar
I'm actually doing what you suggest by going on this site(and others) I knew nothing about auto mechanics 2 months ago. Now I still know nothing, but at least I'm getting somewhere. I ask tons of questions, most probably dumb ones, to further my knowledge. I'm not gonna get an ewp. I just want to know the facts about it to be more informed. It's too expensive, not enough gains, Im a daily driver, and I've had 2 engines burn up on me, so I am very cautions about the cooling system. Yeah teke that helps. I look forward to seeing what you write, and always pay attention when you chime in. thanks
Old Jul 15, 2006 | 04:03 PM
Kevin Blown 95 TA's Avatar
does that help?
It runs off the alternator which charges the battery
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Stay Puft
Apr 20, 2015 06:24 PM
Queens94z28
Dec 20, 2014 09:11 PM
Zone
Jul 29, 2002 07:43 PM
