98 LS1 into 95 Formula info needed
Old Jul 15, 2006 | 07:30 AM
purple95formula's Avatar
Where can I find any information on this swap? Stripping the 98 now and dont know what parts to keep.
Old Jul 15, 2006 | 08:29 AM
AL SS590 M6's Avatar
Moderator
Re: 98 LS1 into 95 Formula info needed
Keep the whole thing until you're done.
Best and easiest would be to pull the whole engine, K-member, a-arms, brakes, trans, trans crossmember, and PCM out the bottom as one piece and stuff it up into your 95.
Old Jul 15, 2006 | 08:57 AM
Capn Pete's Avatar
^^^ You'd be killing at LEAST two birds with one stone there ..... upgrading to the LS1 engine and LS1 brakes!!
Old Jul 16, 2006 | 06:27 AM
Got the whole thing everything is disconnected that I can reach from top.Brakes aren't going to work because pass side is torn off. Going to drop everything out bottom next weekend with help of big backhoe.Any idea where to find wiring diagrams for the 98 ? Im taking wiring harness all the way thru firewall but dont know what will plug up and what i have to splice.
Old Jul 16, 2006 | 07:56 AM
Moderator
Helms manual would be the best. Chilton/Haynes might be detailed enough.
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
Jazsun
Dec 29, 2014 12:14 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
