problem with dual cutouts
Old Aug 23, 2006 | 06:47 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
i want to put manual cutouts right behind my headers, NOT 1 on the I pipe.
but how? with all the bends in the y pipe... there appears to be no place to replace y pipe tubing with a 12 in. straight pipe, which the cutouts im looking at incorporate
what to do??
Old Aug 23, 2006 | 06:52 PM
teke184's Avatar
Re: problem with dual cutouts
put them back a little farther, right after the pipes bend to join at the I-pipe
Old Aug 23, 2006 | 09:32 PM
Bayer-Z28's Avatar
Doesn't say in your sig if you have cats or not.
I'd say, if you don't have cats, chop the Y right after the collector.. Put em in there...
Old Aug 23, 2006 | 10:12 PM
frmula1's Avatar
nope no cats
and teke thats exactly the problem, i don't want them there i want them directly after the header i've heard a ton of cutouts in the I pipe and they just don't seem to work as well
Old Aug 23, 2006 | 10:14 PM
Bayer-Z28's Avatar
^ I think that'd be the ideal place for CO's.. THey do as they say, it compleyeley bypasses the entire exh..
I'm putting mine in place of the cats... (when I get the $$ atleast)
Old Aug 24, 2006 | 06:14 AM
teke184's Avatar
i don't mean in the I-pipe....i mean about 1ft ahead of the merge on the ypipe...right after each side angles in to join
Old Aug 24, 2006 | 10:37 AM
SilverTurtle's Avatar
if you have headers, why dont you get a QTP dual cutout y-pipe? heck, I have one for sale if you want one... its perfect for adding dual electric cutouts.
Old Aug 24, 2006 | 06:29 PM
frmula1's Avatar
i'd consider it as long as it is:
A. 3"
B. aluminum
C. is compatible with my headers, my catback, and my brace and d-shaft loop which i had to modify extensively to make my pacesetter y-pipe fit
D. comes with two MANUAL cutouts already welded togethor
teke: thats EXACTLY the problem... the y-pipe is not straight for a great enough distance on both sides to put a 12" straight pipe in the middle of it ANYWHERE
Old Aug 24, 2006 | 06:45 PM
leadfoot94's Avatar
A. 3"
B. aluminum
So why don't you drill a 3in. hole in your existing pipe and weld on an angled extension with a 3-bolt flange on the end. Problem solved.
Old Aug 24, 2006 | 09:24 PM
Bayer-Z28's Avatar
Can you shorten the cutouts them selves??
Running out of ideas... Can you get a pic of theY pipe so we can maybe combine efforts?
Old Aug 25, 2006 | 10:04 PM
frmula1's Avatar
wouldn't that make it a 90 in the exhaust to make it out the cutout?
i dunno sounds too involved for me
i'll work on those pictures this weekend if i can
alphaauto
Jan 22, 2015 08:02 PM
birdblack
Exhaust System
Jan 4, 2015 09:41 PM
turbo_Z
Aug 19, 2002 10:50 PM
