View Poll Results: how much hp??
350-
20.00%
350-400
60.00%
400+
20.00%
not worth the money
0%
Voters: 5. You may not vote on this poll
ls6 heads???
Old Aug 13, 2006 | 06:48 PM
bandit_ad22's Avatar
ls6 heads???
what kind of gains can i expect from ls6 heads and a tsp torquer v2 cam????
just need about estimates
i have a 98 z28 auto w/
hypertech
3.73 gears
160 stat
runs a 13.1 right now but what could i expect for hp or et after that mod with a set of long tubes pacesetters??
Old Aug 13, 2006 | 09:32 PM
GhostZ28's Avatar
Re: ls6 heads???
your poll makes me laugh! haha it should be in 10 hp increments and even at that it will only run as well as the person who tunes it. sorry for being mean. you need lots of other mods.
As far as heads, regular LS6 heads will only yeild a gain of around 12-15 hp over ls1 castings. the real performance jump is in ported and polished heads. still, the difference between ls1/6 P&P heads is only like 15 hp (depending on cam as well, the bigger the cam, the more hp you'll squeeze out of the heads, like maybe 20 or 25hp on BIG cams)
Old Aug 13, 2006 | 09:35 PM
teke184's Avatar
Re: ls6 heads???
well with boltons and the original Torquer cam...i'm running about 400rwhp.
so with the mild gain of the ls6 heads...i'd say between 400 and 420rwhp depending on tuning.
Old Aug 13, 2006 | 10:49 PM
Re: ls6 heads???
the heads were suppose to be stage to from a company i think thats called bully dog from michigan... no sure about that so i wouldn't quote it but i feel that was the name of the company i would have to ask the guy who has them but right now i have my name on the for 600 with dual springs, the only thing they need is vavle seals they r brand new
Old Aug 13, 2006 | 11:03 PM
WS6NIGHTMARE's Avatar
Re: ls6 heads???
Thats my setup, tuned by Horsepower Engineering..shhhh...400+ and worth it.
Old Aug 14, 2006 | 08:04 AM
teke184's Avatar
Re: ls6 heads???
ported ls6 heads aer a whole different ballgame.
get some flow numbers, combustion chamber size, intake runner size, valve size....
all that will affect how the heads work with the cam
Old Aug 14, 2006 | 10:12 AM
Re: ls6 heads???
does anyone know the costs of gettin ls6 heads opened up??
cnc milled??
or does anyone know where to get the cnc program??
Old Aug 14, 2006 | 12:23 PM
Re: ls6 heads???
the chart says 28.0" for exhaust and intake
and at .550 lift the flow is
intake-barely over 300.0
exhaust-200.0
r these good numbers????
Old Aug 14, 2006 | 03:22 PM
teke184's Avatar
Re: ls6 heads???
300 at .550 is pretty good. not sure i trust them too much.
the 28 is probably the pressure it was flowed tested at.
if those are accurate...there is no need to port them any more. i would spend the few bills and get them flowtested just to confirm. and have the chamber checked so you don't accidentally drop a few points on your compression (although i think ls6 heads have smaller chambers so you should be fine), and maybe have the intake runner checked. a big intake runner will make great numbers at peak on the dyno..but hurt your low/mid range.
Old Aug 14, 2006 | 05:09 PM
Re: ls6 heads???
what company's in michigan would flow test it for me???
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
birdblack
Dec 30, 2014 06:59 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
hotrodyou1
Dec 20, 2014 10:05 PM
