Twin Turbo Question - Wastegates and Blow Off Valves
I understand single turbo applications...to acheave a 16psi boost, T67 turbo, 16psi Wastegate and 16psi blow off valve.
What about twin turbo applications? two T67 turbos, two wastegates 8psi each and 8psi blow off valves...
...is that correct? They share the boost.
Re: Twin Turbo Question - Wastegates and Blow Off Valves
The twin turbo setup would still use 16psi wastegate springs. And BOV springs are 'tuned' for your elevation, not for how much boost you're running.
Yes. Two 9 volt batteries in parallel is still 9 volts, not 18.
Because a BOV requires vacuum and boost to open, spring selection depends on how much vacuum your engine pulls, so it depends on your elevation (and if you have a non-factory cam, etc.)
http://tialsport.com/documents/w3_tial_bov50_sp.pdf
I'll probably get penalized for this but dude you da ****! Now it makes sence. The pdf file you attached rates only for up to 12psi...what if I want to go up to 20-25psi?
That's not boost psi, it's negative psi (vacuum). 1 psi = 2 inches of mercury.
Again, the psi of boost you're running does not factor in anywhere.
LT1runner
33
Jul 24, 2002 01:19 PM
ced8
Jun 24, 2002 11:11 AM
As far as BOV...ELEVATION?
