supercharged stock bottom end ltx dyno results
I just dyno'd my supercharged ltx. Its a ported lt1 heads/hotcam/ LT headers car running stock PCM. P600B blower at 10 psi. Also meth/water injection.
Im not sure if this is good/ bad. Just wanted to post it here.
http://forums.corvetteforum.com/c4-f...post1578762546
Re: supercharged stock bottom end ltx dyno results
Similar build- only major differences being a Comp 'blower' cam with .502/.520 lift and intercooler, no meth.- was only pushing 5psi and turned to 5500rpm and made 476hp/465tq on a dyno jet.
Don't rely simply on dyno numbers- there is no standard calibration so one might read a little 'hotter' than another one.
Get a good cam ground for a supercharger and you'll likely pick up quite a few ponies.
I know my heads are a bottleneck. They are crappily hand_ported lt1 heads. I say that bc they aren't matched to the intake or anything like that.
I'm running the hotcam which isn't exactly a bad cam. It has 112 lsa.
I guess my expectations of 500 rwhp were more for bragging rights. Ill get it to the track and see what it does. If I'm lucky it'll be about 12.1 at the track I run at.
If any of you have any dyno charts please post
It really is fun on the street. I was impressed how flat my tq curve is down low - unusual for a centrifugal. I'm running high spark advance (31 degrees) low in the rpm range and have it backing off to 20 degrees in the 5000 rpm range as boost hits. I'm hoping that timing and the meth/water inj helps keep my stock bottom end intact.
Yeah I don't know why I didn't do better. Did you have worked heads on there? And a stock bottom end?
If you run hard at the track I would be more worried about the rear-end holding together than the bottom end.
Stay conservative with your tune and you shouldn't have an issue with the bottom half. Blowers and nitrous get a bad rep from people trying to get too much power from them. Stay within the limits of what you have and your motor should last a good long time.
Yeah- they were slightly worked stock heads- matched to the heads, but not much more than a clean-up and bowl blend. Still had the stock bottom end at that point too.
10-31-2016 11:09 AM
CARiD
01-27-2015 06:27 AM
