One catch can enough?
Old Apr 22, 2011 | 11:50 PM
LT1 POWR's Avatar
Can I tee both valve cover breathers into one line running to a catch can? Would that provide enough airflow/suction to efficiently remove most hydrocarbons? I plan on running the vacuum line from the catch can to the suction side of the turbo. Theoretically this should work. Or should I retain the throttle body vacuum port and run and inline check valve? Any input?
Old Apr 23, 2011 | 12:43 AM
MikeGyver's Avatar
Re: One catch can enough?
fresh air goes from the throttle body port to the passenger valve cover, air is sucked out of the lifter valley (through the bottom of the intake manifold) and then into the intake manifold.
And theres essentially zero vacuum at the intake of the turbo (unless your air filter is clogged). If you don't believe me simply put a vac gauge there and go drive around.
If you're in speed density mode you can ust put a breather filter on the valve cover and leave the rest of the system normal. It'll still suck fresh air in through the breather filter, and vent blowby to the atmosphere when under boost. If this makes an oily mess, run it into a catch can with a breather filter on it.
Old Apr 23, 2011 | 11:49 PM
LT1 POWR's Avatar
So put one of these into each valve cover, run both the lines into the inlet on the catch can and have a regular breather on the other side of the catch can?
Old Apr 24, 2011 | 02:44 AM
MikeGyver's Avatar
You could yes. You might only need to vent one valve cover (my valve covers don't have any ports on the driver side.)
PCV valves don't hold boost back very well at all, so I put a 1/4" NPT brass check valve on the front port of the manifold (vacuum) and ran a line to where the PCV valve goes in the manifold (gutted the PCV valve).
Old Apr 24, 2011 | 11:02 PM
LT1 POWR's Avatar
I'm running a holley single plane so none of the PCV stuff will work. I'll probably just do a valve on each cover to pull out gasses more evenly.
95craz28
11
Sep 12, 2015 07:47 AM
RX Speed Works
Sep 11, 2015 03:31 PM
RX Speed Works
Aug 11, 2015 11:16 PM
realistyc
Jul 28, 2015 07:32 PM
RX Speed Works
Jul 24, 2015 02:25 PM
