D1SC help
Old Jul 29, 2010 | 08:35 PM
MysticBowtie's Avatar
D1SC help
I'm finishing everything up on my build and am having a really hard time figuring out how to run the intake side of the Procharger. I have a UMI K-member (road race version) that is directly in the way of the 4" tubing. I desperately want to stay away from the dryer hose crap, but can't figure out what to do. The kit was made around the factory K-member, and I now that I have the performance one, of course it has to get in the way. Does anybody else have this set-up, and if so, what did you do? Every other pipe in the system is powder coated aluminum, and the thought of dryer hose is killing me!!
Old Aug 2, 2010 | 09:04 PM
anybody....?
Old Aug 2, 2010 | 11:19 PM
fabgmc4me's Avatar
I'm using the new style procharger inlet. It's made of hard plastic, and fits fine with my tubular k member.
Old Aug 3, 2010 | 10:00 AM
Procharged94Lt1's Avatar
I considered getting one of those too- but spending top dollar on $.05 worth of shaped plastic really bothers me..
Old Aug 5, 2010 | 09:35 AM
97WS6SCharged's Avatar
Talk to somebody who knows how to work with aluminum. It won't be cheap though.
Old Aug 5, 2010 | 11:49 AM
David94TA's Avatar
I went to a local building supply and found a hose that is much more reinforced than the ATI dryer hose and the covering material seems to be tougher. I don't know exactly what it is called (I think is is some sort of exhaust hose) but it would take a lot of force to collapse this. It makes a nice bend at the inlet of the SC and then you can route it however you want. I am very satisfied with it and it is a lot less expensive than fabbing up something or the plastic alternatives.
Old Aug 6, 2010 | 02:51 PM
CALL911's Avatar
https://www.camaroz28.com/forums/sho...ht=metal+inlet
This is the solution to your problem.
You're welcome in advance!
:NOTE:
To cut to the chase, contact Lisa33
Old Aug 8, 2010 | 09:15 PM
That's it, I'll have it made this week.
Cheers,
Ben
bunker
Jan 30, 2016 08:09 PM
bunker
Aug 21, 2015 10:21 AM
95blkss
Jul 13, 2015 01:28 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
Mike383LT1
Jan 20, 2004 11:39 AM
